Pb Argument non facultatif
J'ai un souci dans mon programme qui à l'exécution de celui-ci mon dit : Argument non facultatif.
Le but du programme est de classé des noms de clients par groupe en fonction de certains attributs.
Voici le code :
Sub Bouton2_Cliquer()
Dim PPM As Long, NB_FNC As Integer, QSC As Double, CA As Long
Dim i As Integer, j As Integer
Dim DernLigne As Long
With Worksheets("Feuil1")
For i = 2 To 138
PPM = .Cells(i, "S")
NB_FNC = .Cells(i, "T")
QSC = .Cells(i, "U")
CA = .Cells(i, "V")
'Groupe 8
If NB_FNC = 1 And PPM < 20000 And QSC > 0.85 Then
.Cells(i, "BN") = .Cells(i, "O")
.Cells(i, "BN").Interior.Color = RGB(0 / 176 / 80)
.Cells(i, "BO") = .Cells(i, "S")
.Cells(i, "BO").Interior.Color = RGB(0 / 176 / 80)
.Cells(i, "BP") = .Cells(i, "T")
.Cells(i, "BP").Interior.Color = RGB(0 / 176 / 80)
.Cells(i, "BQ") = .Cells(i, "U")
.Cells(i, "BQ").Interior.Color = RGB(0 / 176 / 80)
.Cells(i, "BR") = .Cells(i, "V")
.Cells(i, "BR").Interior.Color = RGB(0 / 176 / 80)
'Groupe 7
ElseIf NB_FNC = 1 And PPM < 20000 And QSC < 0.85 Then
.Cells(i, "BH") = .Cells(i, "O")
.Cells(i, "BH").Interior.Color = RGB(196 / 215 / 155)
.Cells(i, "BI") = .Cells(i, "S")
.Cells(i, "BI").Interior.Color = RGB(196 / 215 / 155)
.Cells(i, "BJ") = .Cells(i, "T")
.Cells(i, "BJ").Interior.Color = RGB(196 / 215 / 155)
.Cells(i, "BK") = .Cells(i, "U")
.Cells(i, "BK").Interior.Color = RGB(196 / 215 / 155)
.Cells(i, "BL") = .Cells(i, "V")
.Cells(i, "BL").Interior.Color = RGB(196 / 215 / 155)
'Groupe 6
ElseIf NB_FNC = 1 And PPM > 20000 And QSC > 0.85 Then
.Cells(i, "BB") = .Cells(i, "O")
.Cells(i, "BB").Interior.Color = RGB(216 / 228 / 188)
.Cells(i, "BC") = .Cells(i, "S")
.Cells(i, "BC").Interior.Color = RGB(216 / 228 / 188)
.Cells(i, "BD") = .Cells(i, "T")
.Cells(i, "BD").Interior.Color = RGB(216 / 228 / 188)
.Cells(i, "BE") = .Cells(i, "U")
.Cells(i, "BE").Interior.Color = RGB(216 / 228 / 188)
.Cells(i, "BF") = .Cells(i, "V")
.Cells(i, "BF").Interior.Color = RGB(216 / 228 / 188)
'Groupe 5
ElseIf NB_FNC = 1 And PPM > 20000 And QSC < 0.85 Then
.Cells(i, "AV") = .Cells(i, "O")
.Cells(i, "AV").Interior.Color = RGB(235 / 241 / 222)
.Cells(i, "AW") = .Cells(i, "S")
.Cells(i, "AW").Interior.Color = RGB(235 / 241 / 222)
.Cells(i, "AX") = .Cells(i, "T")
.Cells(i, "AX").Interior.Color = RGB(235 / 241 / 222)
.Cells(i, "AY") = .Cells(i, "U")
.Cells(i, "AY").Interior.Color = RGB(235 / 241 / 222)
.Cells(i, "AZ") = .Cells(i, "V")
.Cells(i, "AZ").Interior.Color = RGB(235 / 241 / 222)
'Groupe 4
ElseIf NB_FNC > 2 And PPM < 20000 And QSC > 0.85 Then
.Cells(i, "AP") = .Cells(i, "O")
.Cells(i, "AP").Interior.Color = RGB(255 / 255 / 0)
.Cells(i, "AQ") = .Cells(i, "S")
.Cells(i, "AQ").Interior.Color = RGB(255 / 255 / 0)
.Cells(i, "AR") = .Cells(i, "T")
.Cells(i, "AR").Interior.Color = RGB(255 / 255 / 0)
.Cells(i, "AS") = .Cells(i, "U")
.Cells(i, "AS").Interior.Color = RGB(255 / 255 / 0)
.Cells(i, "AT") = .Cells(i, "V")
.Cells(i, "AT").Interior.Color = RGB(255 / 255 / 0)
'Groupe 3
ElseIf NB_FNC > 2 And PPM < 20000 And QSC < 0.85 Then
.Cells(i, "AJ") = .Cells(i, "O")
.Cells(i, "AJ").Interior.Color = RGB(252 / 213 / 180)
.Cells(i, "AK") = .Cells(i, "S")
.Cells(i, "AK").Interior.Color = RGB(252 / 213 / 180)
.Cells(i, "AL") = .Cells(i, "T")
.Cells(i, "AL").Interior.Color = RGB(252 / 213 / 180)
.Cells(i, "AM") = .Cells(i, "U")
.Cells(i, "AM").Interior.Color = RGB(252 / 213 / 180)
.Cells(i, "AN") = .Cells(i, "V")
.Cells(i, "AN").Interior.Color = RGB(252 / 213 / 180)
'Groupe 2
ElseIf NB_FNC > 2 And PPM > 20000 And QSC > 0.85 Then
.Cells(i, "AD") = .Cells(i, "O")
.Cells(i, "AD").Interior.Color = RGB(250 / 191 / 143)
.Cells(i, "AE") = .Cells(i, "S")
.Cells(i, "AE").Interior.Color = RGB(250 / 191 / 143)
.Cells(i, "AF") = .Cells(i, "T")
.Cells(i, "AF").Interior.Color = RGB(250 / 191 / 143)
.Cells(i, "AG") = .Cells(i, "U")
.Cells(i, "AG").Interior.Color = RGB(250 / 191 / 143)
.Cells(i, "AH") = .Cells(i, "V")
.Cells(i, "AH").Interior.Color = RGB(250 / 191 / 143)
'Groupe 1
ElseIf NB_FNC > 2 And PPM > 20000 And QSC < 0.85 Then
.Cells(i, "X") = .Cells(i, "O")
.Cells(i, "X").Interior.Color = RGB(255 / 0 / 0)
.Cells(i, "Y") = .Cells(i, "S")
.Cells(i, "Y").Interior.Color = RGB(255 / 0 / 0)
.Cells(i, "Z") = .Cells(i, "T")
.Cells(i, "Z").Interior.Color = RGB(255 / 0 / 0)
.Cells(i, "AA") = .Cells(i, "U")
.Cells(i, "AA").Interior.Color = RGB(255 / 0 / 0)
.Cells(i, "AB") = .Cells(i, "V")
.Cells(i, "AB").Interior.Color = RGB(255 / 0 / 0)
Pour les plus téméraires. J'aimerais ensuite afficher ce classement des clients sur 3 colonnes dans la Feuil2, de la ligne 2 à la ligne 44 pour que ca tienne sur une seule page.
En espérant que vous pourrez me venir en aide,
Bonne journée,
Floo73
Pourquoi mets tu des slash pour tes rgb?
Rgb(255/1/1) tu ne donnes qu'un seul argument, le rouge. En effet tu fais deux divisions successives..
Il faut les remplacer par des virgules rgb(255,1,1)
A tester...
Cdlt
'Groupe 8
With .Range("BN" & i & ":BR" & i)
.Value = .Range("O" & i & ":V" & i)
.Interior.Color = RGB(0, 176, 80)
Bonjour à tous les 2,
Merci pour la fulgurance et la pertinence de vos réponses !
Tout marche du tonnerre !
Bonne journée et bonnes vacances à vous,
Floo73
