Optimisation de Code VBA
Bonjour la communauté
qui pourrait m'aider à optimiser cette VBA qui tourne trop lentement ( j'ai 50000 lignes à traiter)
Merci d'avance de vos conseils
Sub commande()
Sheets("SXX 2013").Columns("L").Copy
Sheets("TEST6").Range("A1").Select
ActiveSheet.Paste
ActiveSheet.Columns("A").RemoveDuplicates Columns:=1, Header:= _
        xlYes
 For i = 2 To Sheets("TEST6").Range("A100000").End(xlUp).Row
     With Sheets("SXX 2013")
       Sheets("TEST6").Range("B" & i) = Application.WorksheetFunction.SumIf(.Columns("L"), Sheets("TEST6").Cells(i, 1), .Columns("J"))
       Sheets("TEST6").Range("C" & i) = Application.WorksheetFunction.SumIf(.Columns("L"), Sheets("TEST6").Cells(i, 1), .Columns("J")) - Application.WorksheetFunction.SumIf(.Columns("L"), Sheets("TEST6").Cells(i, 1), .Columns("K")) - Application.WorksheetFunction.SumIf(.Columns("L"), Sheets("TEST6").Cells(i, 1), .Columns("Q"))
       Sheets("TEST6").Range("D" & i) = Sheets("TEST6").Range("C" & i) / Sheets("TEST6").Range("B" & i)
       Sheets("TEST6").Range("E" & i) = Application.WorksheetFunction.SumIf(.Columns("L"), Sheets("TEST6").Cells(i, 1), .Columns("I"))
       Sheets("TEST6").Range("F" & i) = Sheets("TEST6").Range("B" & i) / Sheets("TEST6").Range("E" & i)
Sans fichier
Essayes (sans conviction)
Sub commande()
  With Sheets("TEST6")
    Sheets("SXX 2013").Columns("L").Copy S.Range("A1")
    .Columns("A").RemoveDuplicates Columns:=1, Header:=xlYes
    .Range("B2").Formula = "=SUMIF('SXX 2013'!$L:$L,A2,'SXX 2013'!$J:$J)"
    .Range("C2").Formula = "=SUMIF('SXX 2013'!$L:$L,A2,'SXX 2013'!$J:$J)-SUMIF('SXX 2013'!$L:$L,A2,'SXX 2013'!$K:$K)-SUMIF('SXX 2013'!$L:$L,A2,'SXX 2013'!$Q:$Q)"
    .Range("D2").Formula = "=C2/B2"
    .Range("E2").Formula = "=SUMIF('SXX 2013'!$L:$L,A2,'SXX 2013'!$I:$I)"
    .Range("F2").Formula = "=B2/E2"
    .Range("B2:F2").AutoFill .Range("B2:F" & .Range("A" & Rows.Count).End(xlUp).Row), xlFillSeries
    With .Range("B2:F" & .Range("A" & Rows.Count).End(xlUp).Row)
      .Value = .Value
merci banzai pour ton code mais il y a plus de 67000 lignes à calculer avec des fonctions...
du coup il a pas le temps de calculer que la macro vient coller en valeur brute.
mon fichier est trop lourd pour te l'envoyer
donc voici un extrait sachant que dans "SXX 2013" il y a 100000 lignes et dans "TEST 6" 50000 lignes
32classeur2.xlsm (18.77 Ko)
En limitant dans la formule le nombre de ligne (à la place de prendre toute la colonne)
Je trouve bizarre autant qu'étrange (mais je ne connais pas tout) qu' XL commence un autre boulot sans avoir finit le premier
Essayes
Sub commande()
Dim NbLg As Long
  NbLg = Sheets("SXX 2013").Range("L" & Rows.Count).End(xlUp).Row
    Sheets("SXX 2013").Columns("L").Copy .Range("A1")
    .Range("B2").Formula = "=SUMIF('SXX 2013'!$L$2:$L$" & NbLg & ",A2,'SXX 2013'!$J$2:$J$" & NbLg & ")"
    .Range("C2").Formula = "=SUMIF('SXX 2013'!$L$2:$L$" & NbLg & ",A2,'SXX 2013'!$J$2:$J$" & NbLg & ")-SUMIF('SXX 2013'!$L$2:$L$" & NbLg & ",A2,'SXX 2013'!$K$2:$K$" & NbLg & ")-SUMIF('SXX 2013'!$L$2:$L$" & NbLg & ",A2,'SXX 2013'!$Q$2:$Q$" & NbLg & ")"
    .Range("E2").Formula = "=SUMIF('SXX 2013'!$L$2:$L$" & NbLg & ",A2,'SXX 2013'!$I$2:$I$" & NbLg & ")"
      .Value = .Value
Bonsoir Banzaï
Je suis parti sur une autre piste, c'est à dire faire tous les calculs en mémoire....
Sur le fichier exemple, en mettant 22 000 lignes, dont 11 000 différentes en colonne L, la solution avec formule met en gros une vingtaine de secondes...
Avec le code ci-dessous, un peu plus d'une seconde (nota, j'avais mis les mêmes conditions, "ScreenUpdating" à "False", et "Calculation" en "Manual"
Je te laisse découvrir, et essayer
Bon courage
Sub hub()
Dim Total1 As Object, Total2 As Object, Total3 As Object
Dim Quotient1 As Object, Quotient2 As Object
Dim Cel As Range
Dim It, T
Dim DerLig As Long
With Application
    .ScreenUpdating = False
    .Calculation = xlCalculationManual
T = Timer
Set Total1 = CreateObject("Scripting.Dictionary")
Set Total2 = CreateObject("Scripting.Dictionary")
Set Total3 = CreateObject("Scripting.Dictionary")
Set Quotient2 = CreateObject("Scripting.Dictionary")
Set Quotient1 = CreateObject("Scripting.Dictionary")
    DerLig = .Cells(Rows.Count, "L").End(xlUp).Row
    For Each Cel In .Range("L2:L" & DerLig)
        Total1(Cel.Value) = Total1(Cel.Value) + Cel.Offset(, -2).Value
        Total2(Cel.Value) = Total2(Cel.Value) + Cel.Offset(, -2).Value - Cel.Offset(, -1).Value - Cel.Offset(, 5).Value
        Total3(Cel.Value) = Total3(Cel.Value) + Cel.Offset(, -3).Value
    Next Cel
For Each It In Total1.Keys
    Quotient1(It) = Total2(It) / Total1(It)
    Quotient2(It) = Total1(It) / Total3(It)
Next It
    .Range("A2").Resize(Total1.Count) = Application.Transpose(Total1.Keys)
    .Range("B2").Resize(Total1.Count) = Application.Transpose(Total1.Items)
    .Range("C2").Resize(Total1.Count) = Application.Transpose(Total2.Items)
    .Range("D2").Resize(Total1.Count) = Application.Transpose(Quotient1.Items)
    .Range("E2").Resize(Total1.Count) = Application.Transpose(Total3.Items)
    .Range("F2").Resize(Total1.Count) = Application.Transpose(Quotient2.Items)
    .Columns("D:D").NumberFormat = "0%"
    .Range("B:C,E:F").NumberFormat = "0.00"
Application.Calculation = xlCalculationAutomatic
MsgBox Timer - T
Bonne soirée à tous
Merci Banzai94 et merci cousin Hub
j'aimerais bien comprendre cette macro si tu as le temps de m'expliquer
@ cousin hub : le code bloque à ce passage car "incompatibilité de type".
J'ai fait un test avec + de 300000 lignes sur la feuille "SXX 2013" et ca fonctionne sans soucis...avec comme résultat 63000 lignes en feuille "TEST6"
En revanche des que je depasse 65000 lignes sur la feuille "TEST6" et cela, malgré que sur feuille "SXX 2013" il y a moins de 100000 lignes
Re-,
Quelle ligne est surlignée en "jaune"?
Car tu m'indiques une "partie", et non une ligne...
Pour info, j'utilise un objet "Scripting.Dictionary", objet très rapide, et bien plus rapide qu'un tableau VBA.
Quelques sites en parlent, notamment "boisgontierjacques" (recherche sur G......)
Bon courage
De nouveau, l'utilisation d'un TCD permettrait un gain de traitement
Cdlt
Cousin Hub,
en terme de rapidité, c'est plus que parfait 12sec pour traiter 300 000 lignes
le code met en jaune : .Range("A2").Resize(Total1.Count) = Application.Transpose(Total1.Keys)
Voir fichier avec TCD et 2 champs calculés.
(automatisation par VBA évidemment possible, comme pour le prédent post)
Cdlt
Rechercher des sujets similaires à "optimisation code vba"
