Modification code VBA en boucle
j'ai essayée de faire un code de remplissage les Combobox avec VBA mais il est très long .
vous pouvez m'aider de faire en boucle svp. Car j'ai bcp des equipements >100 et bcp des colones
merci
Private Sub ComboBox2_Change()
Dim index As Integer
index = ComboBox2.ListIndex
ComboBox3.Clear
With Worksheets("Combobox")
    Select Case index
        Case Is = 0
             ComboBox3.List = .Range("C2:C" & .Range("C" & Rows.Count).End(xlUp).Row).Value
        Case Is = 1
               ComboBox3.List = .Range("D2:D" & .Range("D" & Rows.Count).End(xlUp).Row).Value
        Case Is = 2
               ComboBox3.List = .Range("E2:E" & .Range("E" & Rows.Count).End(xlUp).Row).Value
        Case Is = 3
               ComboBox3.List = .Range("F2:F" & .Range("F" & Rows.Count).End(xlUp).Row).Value
        Case Is = 4
               ComboBox3.List = .Range("G2:G" & .Range("G" & Rows.Count).End(xlUp).Row).Value
        Case Is = 5
               ComboBox3.List = .Range("H2:H" & .Range("H" & Rows.Count).End(xlUp).Row).Value
        Case Is = 6
               ComboBox3.List = .Range("I2:I" & .Range("I" & Rows.Count).End(xlUp).Row).Value
        Case Is = 7
               ComboBox3.List = .Range("J2:J" & .Range("J" & Rows.Count).End(xlUp).Row).Value
        Case Is = 8
               ComboBox3.List = .Range("K2:K" & .Range("K" & Rows.Count).End(xlUp).Row).Value
        Case Is = 9
               ComboBox3.List = .Range("L2:L" & .Range("L" & Rows.Count).End(xlUp).Row).Value
    End Select
13classeur2.xlsm (29.18 Ko)
a priori, à tester :
Dim index As Integer, DL As Integer
ComboBox3.Clear
    DL = .Cells.(.Cells.Rows.Count, index + 3).End(xlUp).Row
    ComboBox3.List =. Range(.Cells(2, index + 3), .Cells(DL, index + 3)).Value
Formidable merci bien
Résolu
BONJOUR
ComboBox3.Clear
With Worksheets("Database")
    DL = .Cells(.Cells.Rows.Count, index + 3).End(xlUp).Row
    ComboBox3.List = .Range(.Cells(4, index + 3), .Cells(DL, index + 3)).Value
Rechercher des sujets similaires à "modification code vba boucle"
