j'ai essayée de faire un code SUMIFS avec VBA mais il est très long .
vous pouvez m'aider de faire en boucle svp
merci
Sub SumIfs()
Dim ws1 As Worksheet, ws2 As Worksheet
Dim arrE As Variant, arrH As Variant, arrF As Variant
Dim lr As Long, i As Long
'Dim dt1 As Date, dt2 As Date
Dim Sum As Double, Sum1 As Double
Dim Sum2 As Double, Sum3 As Double
Dim Sum4 As Double, Sum5 As Double, Sum6 As Double
Set ws1 = ThisWorkbook.Worksheets("Conclusion")
Set ws2 = ThisWorkbook.Worksheets("Database")
With ws2
lr = .Cells(.Rows.Count, "F").End(xlUp).Row
arrE = .Range("E2:E" & lr)
arrF = .Range("F2:F" & lr)
For i = 1 To UBound(arrF)
If arrE(i, 1) = ws1.Range("F5").Value Then
Sum = Sum + arrF(i, 1)
ElseIf arrE(i, 1) = ws1.Range("F6").Value Then
Sum1 = Sum1 + arrF(i, 1)
ElseIf arrE(i, 1) = ws1.Range("F7").Value Then
Sum2 = Sum2 + arrF(i, 1)
ElseIf arrE(i, 1) = ws1.Range("F8").Value Then
Sum3 = Sum3 + arrF(i, 1)
ElseIf arrE(i, 1) = ws1.Range("F9").Value Then
Sum4 = Sum4 + arrF(i, 1)
ElseIf arrE(i, 1) = ws1.Range("F10").Value Then
Sum5 = Sum5 + arrF(i, 1)
ElseIf arrE(i, 1) = ws1.Range("F11").Value Then
Sum6 = Sum6 + arrF(i, 1)
ws1.Range("G5").Value = Sum
ws1.Range("G6").Value = Sum1
ws1.Range("G7").Value = Sum2
ws1.Range("G8").Value = Sum3
ws1.Range("G9").Value = Sum4
ws1.Range("G10").Value = Sum5
ws1.Range("G11").Value = Sum6
'MsgBox (Sum)
'MsgBox (Sum1)
