Macro copy d'une base à une autre
bonjour à tous
merci d'avance
l'objectif de transformer la liste des factures de chaque ligne de la feuille REGLEMNT dans la feuille BASE_DETAIL_REGLEMENTS une facture plar ligne
en ajoutant les informations suivantes pour chaque ligne de facture
RefReglementCODE FOURNISSEURDATE DE REGLEMENTREFERENCE CHEQUEECHEANCE TRAITE / DATE DU VIREMENT
Sub copy()
Dim i As Long
Dim sht1 As Worksheet
Dim sht2 As Worksheet
Set sht1 = BaseDetailReglement
Set sht2 = Reglement
  i = 6
x = 3
For i = 6 To 190
For j = 19 To 84
If sht2.Cells(i, j).Value <> "" Then
sht1.Cells(x, 1).Value = sht2.Cells(i, 2).Value
sht1.Cells(x, 2).Value = sht2.Cells(i, 1).Value
sht1.Cells(x, 3).Value = sht2.Cells(i, 6).Value
sht1.Cells(x, 4).Value = sht2.Cells(i, 4).Value
sht1.Cells(x, 5).Value = sht2.Cells(i, 5).Value
sht1.Cells(x, 6).Value = sht2.Cells(i, j).Value
sht1.Cells(x, 7).Value = sht2.Cells(i, j + 1).Value
sht1.Cells(x, 8).Value = sht2.Cells(i, j + 2).Value
x = x + 1
'Next
'End With
End Sub<br>
36mon-fichier.zip (1.46 Mo)
Attention, il y a des formules en colonne P de la feuille "règlement" qui génèrent des références circulaires, supprimez-les ou modifiiez-les.
Votre code corrigé:
Sub Copie()
    Dim sht1 As Worksheet, sht2 As Worksheet
    Dim Tabl_1 As ListObject, Tabl_2 As ListObject
    Dim i As Long, x As Long
    Set sht1 = Sheets("BASE_DETAIL_REGLEMENTS")
    Set sht2 = Sheets("REGLEMENT")
    Set Tabl_1 = sht1.ListObjects("BaseDetailReglment")
    Set Tabl_2 = sht2.ListObjects("reglement")
    DerLig_f2 = Tabl_2.DataBodyRange.Rows.Count
    DerCol_f2 = Tabl_2.DataBodyRange.Columns.Count
    sht1.Range("A3:H10000").ClearContents
    x = 3
    For j = 20 To DerCol_f2 Step 3
        For i = 6 To DerLig_f2
            If sht2.Cells(i, j) <> "" Then
                sht1.Cells(x, "A") = sht2.Cells(i, "B") 'RefReglement
                sht1.Cells(x, "B") = sht2.Cells(i, "A") 'CODE FOURNISSEUR
                sht1.Cells(x, "C") = sht2.Cells(i, "F") 'DATE DE REGLEMENT
                sht1.Cells(x, "D") = sht2.Cells(i, "D") 'REFERENCE CHEQUE
                sht1.Cells(x, "E") = sht2.Cells(i, "E") 'ECHEANCE  TRAITE / DATE DU VIREMENT
                sht1.Cells(x, "F") = sht2.Cells(i, j - 1) 'DATE FACTURE
                sht1.Cells(x, "G") = sht2.Cells(i, j) 'N° FACTURE
                sht1.Cells(x, "H") = sht2.Cells(i, j + 1) 'MONTANT FACTURE
                x = x + 1
    Next j
    Set Tabl_1 = Nothing
    Set Tabl_2 = Nothing
    Set sht1 = Nothing
    Set sht2 = Nothing
Cdlt
merci pour votre réponse
le resultat obtenu par exemple pour le reference reglement=6
661666116/01/202334909451412455,801/12/2022
661666116/01/202334909451413455,844 915,000
661666116/01/202334909451528337,362
661666116/01/2023349094512/01/19001236,4721276919B
661666116/01/20233490945BM000
tandis que le resultat voulu
REGLEMENT FOURNISSEURS
RefReglementCODE FOURNISSEURDATE DE REGLEMENTREFERENCE CHEQUEECHEANCE TRAITE / DATE DU VIREMENTDATE FACTUREN° FACTUREMONTANT FACTURE
661666116/01/2023349094501/12/20221412455,8
661666116/01/2023349094501/12/20221413455,8
661666116/01/2023349094520/12/20221528337,362
bien à vous
Ok, j'avais pas vu que les 13 dernières colonnes étaient masquées, ce qui évidemment me faisait récupérer les valeurs de ces colonnes. voici la macro corrigée.
Sub Copie()
    x = 3
        For j = 20 To DerCol_f2 - 14 Step 3
                x = x + 1
        Next j
    Set sht1 = Nothing
    Set sht2 = Nothing
Cdlt
bonsoir
un autre ajustement de la macro pour toute fin utile
avec le fichier support
un grand merci pour Arturo83
For i = 6 To DerLig_f2+5
25mon-fichier-2.zip (1.30 Mo)
bonne nuit
Sub Copie()
    x = 3
                sht1.Cells(x, "F") = sht2.Cells(i, j - 2) 'DATE FACTURE
                sht1.Cells(x, "G") = sht2.Cells(i, j - 1) 'N° FACTURE
                sht1.Cells(x, "H") = sht2.Cells(i, j)  'MONTANT FACTURE
                x = x + 1
        Next j
    Set sht1 = Nothing
    Set sht2 = Nothing
Je vous ai complètement oublié, voici la macro pour une exécution plus rapide?
Sub Copie()
    Dim i As Long, j As Long
    Dim DerLig_f2 As Long, DerCol_f2 As Long
    Dim Rgl() As Variant
    Dim x As Long
    x = 1
    ReDim Rgl(1 To DerLig_f2 + 5, 1 To DerCol_f2)
    For i = 6 To DerLig_f2 + 5
                If x > UBound(Rgl, 1) Then
                    'Augmente la taille du tableau Rgl
                    ReDim Preserve Rgl(1 To UBound(Rgl, 1) + 10, 1 To DerCol_f2)
                ' Stocke les données dans le tableau Rgl
                Rgl(x, 1) = sht2.Cells(i, "B").Value ' Regl
                Rgl(x, 2) = sht2.Cells(i, "A").Value ' Code
                Rgl(x, 3) = sht2.Cells(i, "F").Value ' Date_Regl
                Rgl(x, 4) = sht2.Cells(i, "D").Value ' Ref_Ch
                Rgl(x, 5) = sht2.Cells(i, "E").Value ' Date_Ech
                Rgl(x, 6) = sht2.Cells(i, j - 2).Value ' Date_Fact
                Rgl(x, 7) = sht2.Cells(i, j - 1).Value ' N°_Fact
                Rgl(x, 8) = sht2.Cells(i, j).Value ' Mont_Fact
                x = x + 1
                If x > DerLig_f2 + 5 Then GoTo Restitution
        Next j
Restitution:
    ' Copie le tableau Rgl dans les colonnes A à H de la feuille Sht1 à partir de la cellule A3
    For i = 1 To x - 1
        For j = 1 To 9
            sht1.Cells(i + 2, j) = Rgl(i, j)
        Next j
Cdlt
Rechercher des sujets similaires à "macro copy base"
