Listbox n'affiche rien
Bonjour a tous
j'ai voulai afficher sur un liste box un restultat de recherche mais rien ne s'affiche! pouvez vous m'aider SVP
voici le code :
Dim critere
Dim Derniereligne As Integer, X As Integer
critere = TextBox1
If Worksheets("Recap").Cells(Rows.Count, 1).End(xlUp).Row = 1 Then
Derniereligne = 2
Derniereligne = Worksheets("Recap").Cells(Rows.Count, 1).End(xlUp).Row
ListBox1.Clear
For X = 1 To Derniereligne
If Feuil1.Cells(X, 3) = critere Then
Me.ListBox1.AddItem Feuil1.Cells(X, 1)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 1) = Worksheets("Recap").Cells(X, 2)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 2) = Worksheets("Recap").Cells(X, 3)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 3) = Worksheets("Recap").Cells(X, 4)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 4) = Worksheets("Recap").Cells(X, 5)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 5) = Worksheets("Recap").Cells(X, 6)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 6) = Worksheets("Recap").Cells(X, 7)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 7) = Worksheets("Recap").Cells(X, 8)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 8) = Worksheets("Recap").Cells(X, 9)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 9) = Worksheets("Recap").Cells(X, 10)
Next X
j'ai corrigé ça mais toujours rien
Dim critere
critere = TextBox1
If Sheets("Recap").Cells(Rows.Count, 1).End(xlUp).Row = 1 Then
Derniereligne = 2
Derniereligne = Sheets("Recap").Cells(Rows.Count, 1).End(xlUp).Row
ListBox1.Clear
If Sheets("recap").Cells(X, 3) = critere Then
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 1) = Sheets("Recap").Cells(X, 2)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 2) = Sheets("Recap").Cells(X, 3)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 3) = Sheets("Recap").Cells(X, 4)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 4) = Sheets("Recap").Cells(X, 5)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 5) = Sheets("Recap").Cells(X, 6)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 6) = Sheets("Recap").Cells(X, 7)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 7) = Sheets("Recap").Cells(X, 8)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 8) = Sheets("Recap").Cells(X, 9)
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 9) = Sheets("Recap").Cells(X, 10)
Next X
avec un fichier on voie mieux
Maurice
ok merci
voici copie exemple de mon fichier
mon problème se voie sur : Feuille "Facture"----bouton " liste facture/imprimer"---bouton "filtre"
merci
16facture.xlsm (94.77 Ko)
Avec un objet tableau, il est préférable d'utiliser la classe associée. Ci-dessous code :
    Dim critere As String
    Dim X As Integer, Y As Integer
    critere = TextBox1
    Me.ListBox1.Clear
    Me.ListBox1.ColumnCount = 11
    With Feuil5.ListObjects(1)
        For X = 1 To .ListRows.Count
            If .ListColumns("Clients").DataBodyRange.Rows(X) = critere Then
                Me.ListBox1.AddItem .ListColumns("Date").DataBodyRange.Rows(X)
                For Y = 2 To Me.ListBox1.ColumnCount - 1
                    Me.ListBox1.List(Me.ListBox1.ListCount - 1, Y - 1) = .ListColumns(Y).DataBodyRange.Rows(X)
                Next Y
        Next X
a voir la modife de userform Recherche
Maurice
31facture.xlsm (86.88 Ko)
merci Maurice
je ne sais pas pourquoi sur le fichier que tu m'as envoyer tous marche, mais quand je copie le macro sur mon classeur le filtre montre seulement la column "DATE"!!
merci de m'aider
Voir le codename & ColumnCount
Maurice
Private Sub UserForm_Activate()
Set Sh = Feuil5 ' = codename de Recap
    Call InitList(1, "")
Sub InitList(Col, MaVar)
Derniereligne = Sh.Cells(Rows.Count, 1).End(xlUp).Row
    With ListBox1
        .Clear
        .ColumnCount = 11 ' a mettre
            For X = 2 To Derniereligne
                If UCase(Sh.Cells(X, Col)) Like UCase(MaVar) & "*" Then
                    .AddItem Sh.Cells(X, 1)
                        For C = 1 To 9
                          .List(.ListCount - 1, C) = Sh.Cells(X, C + 1).Text
                        Next C
            Next X
merci
Rechercher des sujets similaires à "listbox affiche rien"
