Lier des fichiers
Bonsoir à tous
Je cherche à "externaliser" un onglet de mon fichier nommé WISS.
Actuellement dans le code ci après je récupère les données de l'onglet "RENSEIGNEMENTS" qui se trouve à l'intérieur du fichier WISS. J'aimerai que cette onglet ne soit plus dans le fichier WISS, mais qu'il soit dans le fichier RENS dont le chemin serai:
C:\Users\ggetsandrine\Documents\POOL\RENS
Ci dessous le code que j'ai besoin de modifier:
Dim Rep As Byte, I As Byte
If Me.TextBox1.Value = "" Then Exit Sub
With Sheets("RENSEIGNEMENTS").Range("a2:a65536")
Set C = .Find(Me.TextBox1.Value, LookIn:=xlValues, LookAt:=xlWhole)
If Not C Is Nothing Then
UserForm3.TextBox1.Value = UserForm2.TextBox1.Value
Unload UserForm2
UserForm3.TextBox1.Locked = True
For I = 1 To 5
UserForm3.Controls("TextBox" & I).Value = C.Offset(0, I - 1)
Next I
For I = 1 To 22
If C.Offset(0, I + 4) = "X" Then
UserForm3.Controls("CheckBox" & I) = True
Next I
Range("H12").Value = UserForm3.TextBox1
Range("E15").Value = UserForm3.TextBox2
Range("E18").Value = UserForm3.TextBox3
Range("E21").Value = UserForm3.TextBox4
Range("D48").Value = UserForm3.TextBox5
Range("M27").Value = UserForm3.CheckBox1
Range("N27").Value = UserForm3.CheckBox2
Range("O27").Value = UserForm3.CheckBox3
Range("M28").Value = UserForm3.CheckBox4
Range("N28").Value = UserForm3.CheckBox5
Range("O28").Value = UserForm3.CheckBox6
Range("M29").Value = UserForm3.CheckBox7
Range("N29").Value = UserForm3.CheckBox8
Range("O29").Value = UserForm3.CheckBox9
Range("M30").Value = UserForm3.CheckBox10
Range("M31").Value = UserForm3.CheckBox11
Range("N31").Value = UserForm3.CheckBox12
Range("M32").Value = UserForm3.CheckBox13
Range("N32").Value = UserForm3.CheckBox14
Range("O32").Value = UserForm3.CheckBox15
Range("M33").Value = UserForm3.CheckBox18
Range("N33").Value = UserForm3.CheckBox19
Range("M34").Value = UserForm3.CheckBox16
Range("N34").Value = UserForm3.CheckBox17
Range("M35").Value = UserForm3.CheckBox20
Range("N35").Value = UserForm3.CheckBox21
Range("P28").Value = UserForm3.CheckBox22
UserForm3.Show
ActiveSheet.Protect DrawingObjects:=False, Contents:=True, Scenarios:= _
False
Rep = MsgBox("Vérifier le matricule ?", vbYes + vbQuestion, "Personnel Inconnu")
If Rep = vbYes Then UserForm3.TextBox1.Value = UserForm2.TextBox1.Value: Unload UserForm2: UserForm3.Show Else Exit Sub
End SubMerci pour votre aide et vos idées
une méthode brute :
créer une feuille 2 dans le fichier Wiss.xks qui sera la réplique de RENS.xls
chaque cellule de feuille 2 est liée à la cellule correspondante de RENS.xls (par un copier/collagespécialavecliaison)
toute saisie dans RENS est répercutée dans Wiss
ceci fonctionne si ton objectif est séparer les rens de wiss, mais n'allège pas le fichier Wiss
bgrvfe
