La méthode 'value' de l'objet 'Range' a échoué
Bonjour Chers tous,
J'ai un projet de création de formulaire pour la gestion de coopératives. J'ai utilisé le code ci-dessous mais quand je l'exécute j'ai le message d'erreur suivant "la méthode 'value' de l'objet 'Range' a échoué".
Etant novice en VBA, je sollicite votre aide.
'PROCEDURE POUR AJOUTER UNE NOUVELLE COOPERATIVE
Function Ajout_cooperative()
    ThisWorkbook.Sheets("Cooperatives").Activate
        Dim LastRow1 As Long, LastRow2 As Long
        LastRow1 = ThisWorkbook.Sheets("Cooperatives").Cells(Rows.Count, "A").End(xlUp).Row
        LastRow2 = LastRow1 + 1
        With ThisWorkbook.Sheets("Cooperatives")
        .Cells(LastRow2, "B").Value = FrmAjout_scoop.TextBox1.Value
        .Cells(LastRow2, "C").Value = FrmAjout_scoop.TextBox2.Value
        .Cells(LastRow2, "D").Value = FrmAjout_scoop.ComboBox6.Value
        .Cells(LastRow2, "E").Value = FrmAjout_scoop.ComboBox1.Value
        .Cells(LastRow2, "F").Value = FrmAjout_scoop.ComboBox2.Value
        .Cells(LastRow2, "G").Value = FrmAjout_scoop.ComboBox4.Value
        .Cells(LastRow2, "H").Value = FrmAjout_scoop.TextBox6.Value
        .Cells(LastRow2, "I").Value = FrmAjout_scoop.TextBox6.Value
        .Cells(LastRow2, "J").Value = FrmAjout_scoop.TextBox3.Value
        .Cells(LastRow2, "K").Value = FrmAjout_scoop.TextBox4.Value
        .Cells(LastRow2, "L").Value = FrmAjout_scoop.TextBox5.Value
        .Cells(LastRow2, "M").Value = FrmAjout_scoop.ComboBox5.Value
        .Cells(LastRow2, "N").Value = FrmAjout_scoop.TextBox7.Value
        .Cells(LastRow2, "O").Value = FrmAjout_scoop.TextBox13.Value
        .Cells(LastRow2, "P").Value = FrmAjout_scoop.TextBox12.Value
        .Cells(LastRow2, "Q").Value = FrmAjout_scoop.TextBox11.Value
        .Cells(LastRow2, "R").Value = FrmAjout_scoop.TextBox10.Value
        .Cells(LastRow2, "S").Value = FrmAjout_scoop.TextBox9.Value
Call reset_all_controls2
End Function
Function reset_all_controls2()
Dim ctl As MSForms.Control
For Each ctl In FrmAjout_scoop.Controls
Select Case TypeName(ctl)
Case "TextBox"
ctl.Text = ""
Case "CheckBox", "OptionButton", "ToggleButton"
ctl.Value = False
Case "ComboBox", "ListBox"
ctl.ListIndex = -1
End Select
Next ctl
End Function
Bonjour et bienvenu sur le forum
Un fichier est TOUJOURS le bienvenu
Pourquoi ne pas utiliser les tableaux structurés...
Cette macro n'est pas à mettre dans une fonction mais dans l'userform
J'attends un fichier anonymisé...
A+ François
Je complète la réponse de fanfan38.
Utiliser une fonction est inapproprié car une fonction fournit toujours un résultat : Résultat = fonction (paramètre1, paramètre2, ...).
Dans votre cas, vous pouviez utiliser une procédure : Sub ou intégrer votre code directement dans votre UserForm comme le suggère fanfan38.
D'autre part, il vaut mieux utiliser l'objet "Me" représentant le UserForm, plutôt que son nom. Exemple avec code correctement indenté :
Sub reset_all_controls2()
    For Each ctl In Me.Controls
            Case "TextBox"
                ctl.Text = ""
                ctl.Value = False
                ctl.ListIndex = -1
        End Select
    Next ctl
enfin dernier conseil, ne pas laisser les noms de textbox/combobox créés par défaut. Renommez-les pour savoir à quelles données de vos coopératives ils correspondent. Vous aurez ainsi un code plus lisible et moins de chance de vous tromper dans l’attribution de vos données.
Bonjour Thev et Fanfan38, merci pour vos réponses.
J'ai un petit soucis de connexion internet dans la zone où je suis. Comme suggéré pour un traitement plus efficace de ma demande d'aide, je vous joint le fichier du projet en question
Merci grandement
Il y a du boulot
Pour l'instant j'ai fait l'userform frmajout_scoop qui servira pour la creation et la modification des cooperatives...
A+ François
Super. Bien merci
J'ai vu que vous avez retaillé les codes.
Merci grandement
C'était long... mais c'est bon... lol
Ci joint ma solution
A+ François
Merci grandement ça fonctionne parfaitement comme je le voulais.
Merci à tous pour votre aide précieuse.
Rechercher des sujets similaires à "methode value objet range echoue"
