bonjour , j'appel a votre aide pour un problème sur Excel ,l'exécution de la fonction est très lente , voila le code et Merci d'avance :
Sub Mise1()
Dim O As Worksheet
Dim pf As Range 'déclare la variable pf
Dim pr As Range 'déclare la variable pr
Dim cf As Range 'déclare la variable cf
Dim cr As Range 'déclare la variable cr
For Each O In Sheets
Select Case O.Name
Case "Effectifs Flandres Artois", "RTT EMPLOYEUR", "S10", "S09", "S08", "S07", "S06", "S05", "S04", "S03", "S02", "S01", "S52", "S53", "S52", "S51", "S50", "S49", "S48
Case Else
With O
Set pf = .Range("E192:E246")
Set pr = .Range("D6:F180")
For Each cf In pf
For Each cr In pr
If cr.Value = cf.Value Then
cf.Font.ColorIndex = 2
Exit For
Else: cf.Font.ColorIndex = 1
Next cr
Next cf
End Select
Next O
