Integrer code aggrandissement/retrecissement USF dans USF existant
J'ai le code suivant :
Private Sub cmdReset_Click()
    Dim i As VbMsgBoxResult
    i = MsgBox("Do you want to reset the form?", vbYesNo + vbQuestion, "Reset")
    If i = vbNo Then Exit Sub
    Call Initialize_PendingComplaint
Private Sub cmdSubmit_Click()
    i = MsgBox("Do you want to submit the data?", vbYesNo + vbQuestion, "Submit")
    If ValidatePending = False Then Exit Sub
    Dim sh As Worksheet
    Dim iRow As Long
    Set sh = ThisWorkbook.Sheets("Pending_Complaints")
    iRow = sh.Range("A" & Rows.Count).End(xlUp).Row + 1
    With frmComplaint
        sh.Range("A" & iRow).Value = .txtDate.Value
        sh.Range("B" & iRow).Value = .txtEmpName.Value
        sh.Range("C" & iRow).Value = .txtCustName.Value
        sh.Range("D" & iRow).Value = .txtEmail.Value
        sh.Range("E" & iRow).Value = .cmbCountry.Value
        sh.Range("F" & iRow).Value = .cmbReason.Value
        sh.Range("G" & iRow).Value = .cmbPriority.Value
        sh.Range("H" & iRow).Value = IIf(.chkVIP.Value, "Yes", "No")
        sh.Range("I" & iRow).Value = .txtDescription.Value
Private Sub lstPendingComplaints_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
    If Me.lstPendingComplaints.List(Me.lstPendingComplaints.ListIndex, 0) = "" Then Exit Sub
    Load frmResolve
    With frmResolve
        .txtDate.Value = [text(Today(), "DD-MMM-YYYY")]
        .txtDate.Enabled = False
        .txtEmpName.Value = Environ("username")
        .txtEmpName.Enabled = False
        .txtCustName.Value = Me.lstPendingComplaints.List(Me.lstPendingComplaints.ListIndex, 2)
        .txtCustName.Enabled = False
        .txtCustEmail.Value = Me.lstPendingComplaints.List(Me.lstPendingComplaints.ListIndex, 3)
        .txtCustEmail.Enabled = False
        .txtSummary.Value = ""
        .Show
Private Sub MultiPage_Change()
    Dim i As Long, j As Long, k As Long
    If MultiPage.Value = 0 Then
        i = [Countif(Pending_Complaints!G:G, "High")]
        j = [Countif(Pending_Complaints!G:G, "Medium")]
        k = [Countif(Pending_Complaints!G:G, "Low")]
        With frmComplaint
            .frmSummary.Caption = "Pending Complaints Summary"
            .LblHigh.Caption = i
            .lblMedium.Caption = j
            .lblLow.Caption = k
            .lblOverall.Caption = i + j + k
        i = [Countif(Resolved_Complaints!G:G, "High")]
        j = [Countif(Resolved_Complaints!G:G, "Medium")]
        k = [Countif(Resolved_Complaints!G:G, "Low")]
        With frmComplaint
            .frmSummary.Caption = "Resoled Complaints Summary"
            .lblLow.Caption = k
Je souhaite y inserer un code pour ajouter la possibilite de mettre l User Form en plein ecran , retrecir,etc... le code est ci dessous :
Dim Lg As Single
Dim Ht As Single
Dim Fini As Boolean
Dim i As Integer, L As Integer, TB
    InitMaxMin Me.Caption
    Ht = Me.Height
    Lg = Me.Width
    For i = 1 To 31: ListJ.AddItem i: Next
    TB = Array("Janvier", "Février", "Mars", "Avril", "Mai", "Juin", "Juillet", "Août", "Septembre", "Octobre", "Novembre", "Décembre")
    For i = 0 To 11: CbMois.AddItem TB(i): Next
    For i = Year(Date) - 1 To Year(Date) - 80 Step -1: CbAnnee.AddItem i: Next
Private Sub UserForm_Resize()
Dim RtL As Single, RtH As Single
    If Me.Width < 300 Or Me.Height < 200 Or Fini Then Exit Sub
    RtL = Me.Width / Lg
    RtH = Me.Height / Ht
    Me.Zoom = IIf(RtL < RtH, RtL, RtH) * 100
Private Sub UserForm_Terminate()
    Fini = True
A quel endroit du code initial dois-je ajouter celui la et ques dois je retirer/modifier pour le fusionner avec l autre ?
Merci!
Rechercher des sujets similaires à "integrer code aggrandissement retrecissement usf existant"
