Filtre Userform
S
j'ai cette usf de recherche qui fonctionne bien
Dim f, choix(), rng, BD(), Ncol, ColVisu()
Private Sub ListBox1_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
UserForm2_1.Show
Me.Left = Application.Left + Application.Width / 2 - Me.Width / 2
Me.Top = Application.Top + Application.Height / 2 - Me.Height / 2
Set f = Sheets("cable")
ColVisu = Array(1, 2, 3, 4, 5, 7, 8, 9, 10) ' colonnes à visualiser
Set rng = f.Range("A3:N" & f.[A65000].End(xlUp).Row)
BD = rng.Value
Ncol = UBound(ColVisu) + 1
'-- en têtes de colonne ListBox
X = 22
Y = Me.ListBox1.Top - 12
For Each K In ColVisu
Set Lab = Me.Controls.Add("Forms.Label.1")
Lab.Caption = f.Cells(1, K)
Lab.Top = Y
Lab.Left = X
X = X + f.Columns(K).Width * 0.9
temp = temp & f.Columns(K).Width * 0.9 & ";"
temp = Left(temp, Len(temp) - 1)
Me.ListBox1.ColumnCount = UBound(ColVisu) + 1
Me.ListBox1.ColumnWidths = temp
TblTmp = rng.Value
For i = LBound(BD) To UBound(BD)
ReDim Preserve choix(1 To i)
choix(i) = choix(i) & BD(i, K) & " * "
Next K
'--- valeurs initiales dans ListBox
Dim Tbl(): ReDim Tbl(1 To UBound(BD), 1 To Ncol)
For i = 1 To UBound(BD)
c = 0
c = c + 1: Tbl(i, c) = BD(i, K)
Next K
'TriMultiCol Tbl, LBound(Tbl), UBound(Tbl), 1
Me.ListBox1.List = Tbl
Me.Label1.Caption = Me.ListBox1.ListCount & " Ligne(s)"
Private Sub TextBox1_Change()
If Me.TextBox1 <> "" Then
mots = Split(Trim(Me.TextBox1), " ")
Tbl = choix
For i = LBound(mots) To UBound(mots)
Tbl = Filter(Tbl, mots(i), True, vbTextCompare)
If UBound(Tbl) > -1 Then
Dim b(): ReDim b(1 To UBound(Tbl) + 1, 1 To Ncol)
For i = LBound(Tbl) To UBound(Tbl)
a = Split(Tbl(i), "*")
For K = 1 To Ncol: b(i + 1, K) = a(K - 1): Next K
Me.ListBox1.List = b
Me.Label1.Caption = UBound(Tbl) + 1 & " Ligne(s)"
UserForm_Initialize
je voudrais rajouter 2 checkbox qui filtres les résultats un affiche pas les lignes dont la cellule h contient le mot vide et une autre qui n'affiche pas les lignes dont la colonne j contient le mot renvoyer
rajouter les checbox sa je c faire mais la partie filtre non
merci
