Explication Code
Est-ce que quelqu'un pourrait m'expliquer ce code ?
Mairon
RefreshOverview
Dim Shell As New Shell32.Shell
Dim Folder As Shell32.Folder
Dim File As Shell32.FolderItem
Dim strFiles() As String
If Intersect(Target, Range("_OVERVIEW")) Is Nothing Then Exit Sub
strYEAR = Worksheets("HOME").Range("_YEAR")
If Not Intersect(Target, Worksheets("HOME").Columns(3).EntireColumn) Is Nothing Then
If Right(Worksheets("HOME").Range("_DIR_INPUT1").Text, 1) = "\" Then
strDIR = Worksheets("HOME").Range("_DIR_INPUT1").Text
strDIR = Worksheets("HOME").Range("_DIR_INPUT1").Text & "\"
If Right(Worksheets("HOME").Range("_DIR_INPUT2").Text, 1) = "\" Then
strDIR = Worksheets("HOME").Range("_DIR_INPUT2").Text
strDIR = Worksheets("HOME").Range("_DIR_INPUT2").Text & "\"
Set Folder = Shell.Namespace(strDIR)
strQuery = Worksheets("HOME").Range("_FILTER") & "_" & Intersect(Target.EntireRow, ActiveSheet.Columns(2).EntireColumn) & "_" & strYEAR & "*.xls*"
strFiles() = GetFiles(strDIR, strQuery)
If UBound(strFiles) > 0 Then
strFullPath = strDIR & strFiles(UBound(strFiles))
FillInWorksheet (strFullPath)
Cancel = True
