Excel templates to PDF
Hello,
I am delighted to use the forum for the first time.
I encounter an issue with my excel vba function.
Not being a coder, I went online looking for some vba code that would allow me to "print" a template version ("Template" spreadsheet) of the rows info filled on a first sheet ("Main" spreadsheet).
So I found something that works but I would like to amend two things ! (questions are right below the code)
Here is the code :
Sub FillOutTemplate()
    response = MsgBox("Are you sure you want to save ?", vbYesNo)
    If response = vbNo Then
        MsgBox ("Operation cancelled.")
        Exit Sub
    rspn = InputBox("Please enter password")
    If rspn <> "secret" Then
        MsgBox "Operation cancelled."
        Exit Sub
    Dim LastRw As Long, Rw As Long, Cnt As Long
    Dim dSht As Worksheet, tSht As Worksheet
    Dim MakeBooks As Boolean, SavePath As String
    Application.ScreenUpdating = False 'speed up macro execution
    Application.DisplayAlerts = False 'no alerts, default answers used
    Set dSht = Sheets("Main") 'sheet with data on it starting in row4
    Set tSht = Sheets("Template") 'sheet to copy and fill out
     'Option to create separate workbooks
    MakeBooks = MsgBox("Create separate workbooks?" & vbLf & vbLf & _
    "YES = template will be copied to separate workbooks." & vbLf & _
    "NO = template will be copied to sheets within this same workbook", _
    vbYesNo + vbQuestion) = vbYes
    If MakeBooks Then 'select a folder for the new workbooks
        MsgBox "Please select a destination to save the Personal Information Templates"
        Do
            With Application.FileDialog(msoFileDialogFolderPicker)
                .AllowMultiSelect = False
                .Show
                If .SelectedItems.Count > 0 Then 'a folder was chosen
                    SavePath = .SelectedItems(1) & "\"
                    Exit Do
                Else 'a folder was not chosen
                    If MsgBox("Do you wish to abort?", _
                    vbYesNo + vbQuestion) = vbYes Then Exit Sub
        Loop
     'Determine last row of data then loop through the rows one at a time
    LastRw = dSht.Range("A" & Rows.Count).End(xlUp).Row
    For Rw = 4 To LastRw
        tSht.Copy After:=Worksheets(Worksheets.Count) 'copy the template
        With ActiveSheet 'fill out the form
             'edit these rows to fill out your form, add more as needed
            .Name = dSht.Range("F" & Rw)
            .Range("E1").Value = dSht.Range("A" & Rw).Value
            .Range("B2").Value = dSht.Range("F" & Rw).Value
            .Range("C2").Value = dSht.Range("G" & Rw).Value
            .Range("E2").Value = dSht.Range("E" & Rw).Value
            .Range("D4").Value = dSht.Range("F" & Rw).Value
            .Range("D6").Value = dSht.Range("G" & Rw).Value
            .Range("D8").Value = dSht.Range("H" & Rw).Value
            .Range("D9").Value = dSht.Range("I" & Rw).Value
            .Range("D11").Value = dSht.Range("J" & Rw).Value
            .Range("D12").Value = dSht.Range("K" & Rw).Value
            .Range("D13").Value = dSht.Range("L" & Rw).Value
            .Range("D15").Value = dSht.Range("M" & Rw).Value
            .Range("D16").Value = dSht.Range("N" & Rw).Value
            .Range("D17").Value = dSht.Range("O" & Rw).Value
            .Range("D19").Value = dSht.Range("P" & Rw).Value
            .Range("D20").Value = dSht.Range("Q" & Rw).Value
            .Range("D21").Value = dSht.Range("R" & Rw).Value
            .Range("D23").Value = dSht.Range("S" & Rw).Value
            .Range("D24").Value = dSht.Range("T" & Rw).Value
            .Range("D25").Value = dSht.Range("U" & Rw).Value
            .Range("D26").Value = dSht.Range("V" & Rw).Value
            .Range("D27").Value = dSht.Range("W" & Rw).Value
            .Range("D28").Value = dSht.Range("X" & Rw).Value
            .Range("D29").Value = dSht.Range("Y" & Rw).Value
            .Range("D31").Value = dSht.Range("Z" & Rw).Value
            .Range("D32").Value = dSht.Range("AA" & Rw).Value
            .Range("D34").Value = dSht.Range("AB" & Rw).Value
            .Range("D36").Value = dSht.Range("AC" & Rw).Value
        If MakeBooks Then 'if making separate workbooks from filled out form
            ActiveSheet.Move
            ActiveWorkbook.SaveAs SavePath & Range("E2").Value, xlNormal
            ActiveWorkbook.Close False
        Cnt = Cnt + 1
    Next Rw
    dSht.Activate
    If MakeBooks Then
        MsgBox "Workbooks created: " & Cnt
        MsgBox "Worksheets created: " & Cnt
There are two things I would like to fix,
1) How to delete the option of choosing between saving all the templates in the same workbook ?? I would like that the only option is to save the templates in separate workbooks.
("YES = template will be copied to separate workbooks." & vbLf & _
"NO = template will be copied to sheets within this same workbook", _)
2) How to instead of generating multiple workbooks, it would generate multiple PDF ? Is there a lot to do to adapt the code ?
Voilà, Many thanks in advance!
Hello,
If you want an English-speaking forum, you can go possibly on mrexcel.com
(if it's more easy for you )
P.
Hello,
Désolé je n'ai pas fait attention en postant.
Je parle francais il n'y a pas de soucis je vais reposter en francais :
coolworld a écrit :
J'ai trouvé en cherchant sur le web une macro VBA qui me permet de transférer automatiquement les données remplies dans un spreadsheet ("Main") vers un autre (Template) et qui génère automatiquement un nouveau workbook pour chaque ligne remplie dans le premier spreadsheet.
Tout fonctionne mais j'aurais deux questions (en bas du code)
Voici le code :
        Exit Sub
        Exit Sub
        Do
                .Show
                    Exit Do
        Loop
            ActiveSheet.Move
        Cnt = Cnt + 1
    Next Rw
    dSht.Activate
    If MakeBooks Then
2 Questions
1) Comment supprimer la possibilité de générer les workbooks dans le même workbook ?
2) Est-il possible à la place de générer des workbooks excel de générer des fichiers PDF ? Cela implique-t-il une lourde modification du code ?
Voilà, merci d'avance
A tester car sans fichier joint...
'Option Explicit
        MsgBox "Operation cancelled.", vbInformation
        Exit Sub
        Exit Sub
    With Application
    Do
            .Show
                Exit Do
    Loop
        With ActiveSheet
            .ExportAsFixedFormat Type:=xlTypePDF, _
                                 Filename:=SavePath & .Range("E2").Value & ".pdf", _
                                 quality:=xlQualityMinimum, _
                                 IncludeDocProperties:=True, _
                                 IgnorePrintAreas:=True, _
                                 OpenAfterPublish:=False
        Cnt = Cnt + 1
    Next Rw
    ActiveSheet.Delete
    dSht.Activate
    MsgBox "PDF files created: " & Format(Cnt, "00")
Waw, c'est super tout fonctionne !
Merci Jean-Eric et Patrick!
Je n'hésiterai pas à revenir sur le forum :p
Rechercher des sujets similaires à "templates pdf"
