Erreur introuvable
Je me permets de vous solliciter car cela fait plusieurs heures que je cherche et je ne parviens pas à trouver ce qui bloque avec mon code.
Contexte : je veux créer un fichier pour mon boulot qui me permette de trouver le prix d'articles (en l’occurrence cylindre ou clé) en fonction de certaines informations saisie par l'utilisateur sur une feuille Excel.
Problème : quand mon code s'exécute (à chaque modification de ma feuille), il tourne sans s'arrêter et plante mon fichier.
Voici mon code (onglet "Find a price") :
'Let's calculate these prices :)
'But first, let's go for some explanations of my code :
'*** Named cells ***
'I named all of the user cells to allow me to use the name in my vba code.
'Okay but why?
'=> because if I decide to change the design of my user form sheet, I wouldn't have to update the cells adress in my code
'Indeed if I use named cells, I can change their adress without have to update the code!
'All the cells in the sheet "find a price" are like "fp_XXX"
'All the cells in the sheet "Make a quote" are like "mq_XXX"
'All the cells in the sheet "Source data" are like "sd_XXX"
'"c" will always means column and "r" row.
'*** Structure of this code ***
'First, I will calculate all the different elements (and potential added value) which constitute the price of the cylinders/keys
'And then, I will finally calculate these prices
'Base price of the cylinder
Dim base_cyl_price As Currency
    'Each cylinder has a base price depending on which profile and which cylinder type it is
    base_cyl_price = Application.WorksheetFunction.Index(Worksheets("Src_data").Range("tbl_base_cyl_price"), Application.WorksheetFunction.Match(Worksheets("Find a price").Range("fp_profile"), Worksheets("Src_data").Range("sd_profiles"), 0), Application.WorksheetFunction.Match(Worksheets("Find a price").Range("fp_cyl_type"), Worksheets("Src_data").Range("sd_cyl_types"), 0))
    'We will add in the final formula the value of the potential extensions and other added values
'Extension price
Dim extension_price As Currency
Dim extension_nbr As Byte
    'We will determine how many extensions there are
    extension_nbr = Application.VLookup((Worksheets("Find a price").Range("fp_ins_length") & Worksheets("Find a price").Range("fp_out_length")), Worksheets("Extensions").Range("tble_extensions"), 2, False)
    'And then get the price of all these potential extensions
    If extension_nbr <= 10 Then
        extension_price = extension_nbr * Worksheets("Src_data").Range("sd_adval_ext_1")
        extension_price = extension_nbr * Worksheets("Src_data").Range("sd_adval_ext_2")
'Base price of the key
Dim base_key_price As Currency
    'If the client wants a supplementary key with a cylinder, no matter if the plan is 6 months older or no, in the other cases, we first check this point
    If Worksheets("Find a price").Range("fp_key_type") = "Supplementary key with cylinder" Then
        base_key_price = Application.WorksheetFunction.Index(Worksheets("Src_data").Range("tbl_base_key_price"), Application.WorksheetFunction.Match(Worksheets("Find a price").Range("fp_profile"), Worksheets("Src_data").Range("sd_profiles"), 0), 1)
        If Worksheets("Find a price").Range("fp_ext_6_yn") = "No" Then
            base_key_price = Application.WorksheetFunction.Index(Worksheets("Src_data").Range("tbl_base_key_price"), Application.WorksheetFunction.Match(Worksheets("Find a price").Range("fp_profile"), Worksheets("Src_data").Range("sd_profiles"), 0), Application.WorksheetFunction.Match(Worksheets("Find a price").Range("fp_key_type"), Worksheets("Src_data").Range("sd_key_types"), 0))
            base_key_price = Worksheets("Src_data").Range("sd_key_price_6")
'Discount rate
Dim discount_rate As Variant
    'We just take the rate input by the user
    discount_rate = Worksheets("Find a price").Range("fp_discount_rate")
'Potential added value for the pins
Dim adval_pin As Currency
    'We just add the potential added value if the client wants a 6 or 7 pins system
    If Worksheets("Find a price").Range("fp_pin") = 6 Then
        adval_pin = Worksheets("Src_data").Range("sd_adval_6pins")
        If Worksheets("Find a price").Range("fp_pin") = 7 Then
            adval_pin = Worksheets("Src_data").Range("sd_adval_7pins")
            adval_pin = 0
'Potential added value for the system
Dim adval_system As Currency
    'We just add the added value for HS systems or GHS ones
    If Worksheets("Find a price").Range("fp_system") = "HS" Then
        adval_system = Worksheets("Src_data").Range("sd_adval_HS")
        If Worksheets("Find a price").Range("fp_system") = "GHS" Then
            adval_system = Worksheets("Src_data").Range("sd_adval_GHS")
            adval_system = 0
'Potential added value if keyplan extension
Dim adval_not_init As Currency
Dim adval_6months As Currency
    'We add the FHZ if the client is not the initiator of the keyplan (22% added-value)
    If Worksheets("Find a price").Range("fp_ext_init_yn") = "No" Then
        adval_not_init = Worksheets("Src_data").Range("sd_adval_not_init")
        adval_not_init = 0
    'We add the old system added-value of 7.98€ if the keyplan is 6 months old or more
    If Worksheets("Find a price").Range("fp_ext_6_yn") = "Yes" Then
        adval_6months = Worksheets("Src_data").Range("sd_adval_6months")
        adval_6months = 0
'Potential added value for the finishes
Dim adval_finishes As Currency
    'To do...
'Potential added value for the knob
Dim adval_knob As Currency
    'To do...
'Let's now calculate the price of the cylinder :)
Dim cylinder_price As Currency
    'This is the final formula to calculate the cylinder price, we will just sum up all the things we previously calculated above ;)
    cylinder_price = (base_cyl_price + extension_price + adval_pin + adval_system + adval_6months) * (1 + adval_not_init) * (1 - discount_rate)
    Worksheets("Find a price").Range("fp_cyl_price") = cylinder_price
'And let's now calculate the price of the key :)
Dim key_price As Currency
    'And this is the same for the keys (in more easy)
    key_price = base_key_price * (1 + adval_not_init) * (1 - discount_rate)
    Worksheets("Find a price").Range("fp_key_price") = key_price
Ainsi que mon fichier (rien n'est confidentiel) :
75tarifs-2020-v14.xlsm (556.03 Ko)
Si quelqu'un trouve une solution.. Je prends!
Vip4rk
Quelques conseils pour faciliter la lecture d'un code, et identifier plus facilement les erreurs :
  • Pas de saut de lignes à tout va
  • Pas des tartines de commentaires : commenter c'est bien, mais autant aller à l'essentiel
  • Eviter d'alourdir le code avec des références à rallonge et répétées : on déclare les feuilles avec des noms courts et compréhensibles, et/ou on utilise With Objet ... End With (voir exemple ci dessous)
With Sheets("Nom Feuille")
    .Range("A1") = "Bonjour"
    .Range("B1") = "C'est plus facile à lire !"
- On groupe toutes les déclarations de variable en début de macro, jamais en cours d'utilisation !
Un fois qu'on y verra plus clair, on pourra s'attaquer au cœur de ton problème...
utilise application.enableevents=false et true au debut et à la fin de ta macro événementielle.
ta macro s'exécute quand une cellule de ta feuille est modifiée. or tu modifies (enfin je pense), des cellules de ta feuilles dans ta macro, tu rentres donc dans une boucle sans fin, qui fait planter excel.
Bonjour @Pedro22
Je te remercie pour tes remarques constructives.
Il est vrai que j'ai voulu coder "proprement" mais que ce n'était sans pas le cas!
Je vais suivre tes conseils.
Bonjour @h2so4
Effectivement je pense que tu as vu juste...
Je vais essayer tout de suite mais ça semble logique (je m'étonne de ne pas y avoir pensé rrrh).
Merci!
Vip4rk
C'était bien ça @h2so4, merci!
@Pedro22, j'ai commencé à cleaner mon code comme tu me l'a préconisé.
discount_rate = Range("fp_discount_rate")
base_cyl_price = Application.WorksheetFunction.Index(Worksheets("Src_data").Range("tbl_base_cyl_price"), Application.WorksheetFunction.Match(Range("fp_profile"), Worksheets("Src_data").Range("sd_profiles"), 0), Application.WorksheetFunction.Match(Range("fp_cyl_type"), Worksheets("Src_data").Range("sd_cyl_types"), 0))
extension_nbr = Application.VLookup((Range("fp_ins_length") & Range("fp_out_length")), Worksheets("Extensions").Range("tble_extensions"), 2, False)
If Range("fp_key_type") = "Supplementary key with cylinder" Then
    base_key_price = Application.WorksheetFunction.Index(Worksheets("Src_data").Range("tbl_base_key_price"), Application.WorksheetFunction.Match(Range("fp_profile"), Worksheets("Src_data").Range("sd_profiles"), 0), 1)
    If Range("fp_ext_6_yn") = "No" Then
        base_key_price = Application.WorksheetFunction.Index(Worksheets("Src_data").Range("tbl_base_key_price"), Application.WorksheetFunction.Match(Range("fp_profile"), Worksheets("Src_data").Range("sd_profiles"), 0), Application.WorksheetFunction.Match(Range("fp_key_type"), Worksheets("Src_data").Range("sd_key_types"), 0))
If Range("fp_pin") = 6 Then
    If Range("fp_pin") = 7 Then
        adval_pin = 0
If Range("fp_system") = "HS" Then
    If Range("fp_system") = "GHS" Then
        adval_system = 0
If Range("fp_ext_init_yn") = "No" Then
    adval_not_init = 0
If Range("fp_ext_6_yn") = "Yes" Then
    adval_6months = 0
Vip4rk
ça évolue dans le bon sens !
J'ai repris ton code pour modifier certains éléments (à tester) :
Dim base_cyl_price As Currency, extension_price As Currency, base_key_price As Currency, adval_pin As Currency, adval_system As Currency, adval_not_init As Currency, adval_6months As Currency
Dim adval_finishes As Currency, adval_knob As Currency, cylinder_price As Currency, key_price As Currency
With Worksheets("Src_data")
    base_cyl_price = Application.WorksheetFunction.Index(.Range("tbl_base_cyl_price"), Application.WorksheetFunction.Match(Range("fp_profile"), .Range("sd_profiles"), 0), Application.WorksheetFunction.Match(Range("fp_cyl_type"), .Range("sd_cyl_types"), 0))
    If extension_nbr <= 10 Then extension_price = extension_nbr * .Range("sd_adval_ext_1") Else extension_price = extension_nbr * .Range("sd_adval_ext_2")
        base_key_price = Application.WorksheetFunction.Index(.Range("tbl_base_key_price"), Application.WorksheetFunction.Match(Range("fp_profile"), .Range("sd_profiles"), 0), 1)
            base_key_price = Application.WorksheetFunction.Index(.Range("tbl_base_key_price"), Application.WorksheetFunction.Match(Range("fp_profile"), .Range("sd_profiles"), 0), Application.WorksheetFunction.Match(Range("fp_key_type"), .Range("sd_key_types"), 0))
        Else: base_key_price = .Range("sd_key_price_6")
        adval_pin = .Range("sd_adval_6pins")
        If Range("fp_pin") = 7 Then adval_pin = .Range("sd_adval_7pins") Else adval_pin = 0
        adval_system = .Range("sd_adval_HS")
        If Range("fp_system") = "GHS" Then adval_system = .Range("sd_adval_GHS") Else adval_system = 0
    If Range("fp_ext_init_yn") = "No" Then adval_not_init = .Range("sd_adval_not_init") Else adval_not_init = 0
    If Range("fp_ext_6_yn") = "Yes" Then adval_6months = .Range("sd_adval_6months") Else adval_6months = 0
@Pedro22, super cette fonction With!
Ca marche parfaitement
Merci!
Vip4rk
Rechercher des sujets similaires à "erreur introuvable"
