Erreur for without next
J'ai fait ma macro, mais j'ai toujours l'erreur for without next. Voyez-vous où est mon erreur?
Sub Addpictures()
Application.Calculation = xlManual
Dim i As Integer
Dim j As Integer
Dim Filename As String
Dim Path As String
Dim ObjFSO As Object
Dim ObjFolder As Object
Dim ObjectFile As Object
Worksheets("Corporate").Activate
ActiveSheet.DrawingObjects.Delete
On Error Resume Next
Set ObjFSO = CreateObject("Scripting.FileSystemObject")
Set ObjFolder = ObjFSO.GetFolder("\\saneth03\StylesImage\")
For j = 7 To 50
For i = 5 To 50
If Worksheets("Corporate").Cells(i, j).Value = "" Then
'do nothing
Filename = Worksheets("Corporate").Cells(i, j).Value
For Each ObjectFile In ObjFolder.Files
If ObjectFile.Name Like (Filename & "*") Then
With ActiveSheet.Pictures.Insert(ObjectFile.Path)
With .ShapeRange.LockAspectRatio = msoFalse
.Height = 80
.Width = 50
.Left = ActiveSheet.Cells(i, j).Left
.Top -ActiveSheet.Cells(i, j).Top
.Placement = 1 'locks the picture to a cell
i = i + 1
j = j + 25
Next ObjectFile
Sans garantie de résultat.
Sub AddPictures()
Dim ws As Worksheet
Dim ObjFSO As Object, ObjFolder As Object, ObjectFile As Object
Dim I As Long, J As Long
Application.Calculation = xlCalculationManual
Set ws = ActiveWorkbook.Worksheets("Corporate")
ws.DrawingObjects.Delete
For J = 7 To 50 Step 25
For I = 5 To 50
If ws.Cells(I, J).Value <> "" Then
With ws.Pictures.Insert(ObjectFile.Path)
.Height = 80
.Width = 50
.Left = ws.Cells(I, J).Left
.Top = ws.Cells(I, J).Top
Next ObjectFile
Next I
Next J
End SubBonjour,
il manquait 2 next ( i et j)
Sub Addpictures()
Dim i As Integer
Dim j As Integer
Dim Path As String
For j = 7 To 50
For i = 5 To 50
'do nothing
.Height = 80
.Width = 50
i = i + 1
j = j + 25
Next ObjectFile
Next j
