Erreur 9 VBA
voila mon ocde marcher tres bien hier mais je sais pas pourquoi il ne veut plus marcher
il me dis que jai un pb au niveau de :
        dernligne = ThisWorkbook.Sheets("Feuil1").Range("A" & .Rows.Count).End(xlUp).Row
si vous pouviez m'aider merci
ci joint le code entier
Sub MONTANT_INDEMNITE_PRINCIPALE()
    Dim Date_Souscription_Adhésion As Range, Statut_Technique_Sinistre As Range
    Dim Montant_Ind_Principale As Range
    Dim dernligne As Long
    Dim i As Integer
    Dim sa As String
    Dim montant As String
    Dim tt1, tt2, tt3, tt4, tt5, tt6, tt7, tt8, tt9, tt10, tt11, tt12 As Double
    Dim tt13, tt14, tt15, tt16, tt17, tt18, tt19, tt20, tt21, tt22, tt23, tt24 As Double
    Dim tt25, tt26, tt27, tt28, tt29, tt30, tt31, tt32, tt33, tt34, tt35, tt36 As Double
    Dim s As Double
    Dim Mois As Integer
    With Worksheets("Feuil1")
        Set Date_Souscription_Adhésion = ThisWorkbook.Sheets("Feuil1").Range("B2:B" & dernligne)
        Set Montant_Ind_Principale = ThisWorkbook.Sheets("Feuil1").Range("E2:E" & dernligne)
        Set Statut_Technique_Sinistre = ThisWorkbook.Sheets("Feuil1").Range("D2:D" & dernligne)
    i = 2
   For i = 2 To dernligne
        sa = Cells(i, 4)
        montant = Cells(i, 5)
        Mois = Month(Cells(i, 2))
        If sa <> "Terminé - Refusé après instruction" Then
            If Year(Cells(i, 2).Value = 2015) Then
                Select Case Mois
                    Case Is = 1
                        tt1 = tt1 + CInt(montant)
                    Case Is = 2
                        tt2 = tt2 + CInt(montant)
                    Case Is = 3
                        tt3 = tt3 + CInt(montant)
                    Case Is = 4
                        tt4 = tt4 + CInt(montant)
                    Case Is = 5
                        tt5 = tt5 + CInt(montant)
                    Case Is = 6
                        tt6 = tt6 + CInt(montant)
                    Case Is = 7
                        tt7 = tt7 + CInt(montant)
                    Case Is = 8
                        tt8 = tt8 + CInt(montant)
                    Case Is = 9
                        tt9 = tt9 + CInt(montant)
                    Case Is = 10
                        tt10 = tt10 + CInt(montant)
                    Case Is = 11
                        tt11 = tt11 + CInt(montant)
                    Case Is = 12
                        tt12 = tt12 + CInt(montant)
                End Select
            If Year(Cells(i, 2).Value) = 2016 Then
                Select Case Mois
                    Case Is = 13
                        tt13 = tt13 + CInt(montant)
                    Case Is = 14
                        tt14 = tt14 + CInt(montant)
                    Case Is = 15
                        tt15 = tt15 + CInt(montant)
                    Case Is = 16
                        tt16 = tt16 + CInt(montant)
                    Case Is = 17
                        tt17 = tt17 + CInt(montant)
                    Case Is = 18
                        tt18 = tt18 + CInt(montant)
                    Case Is = 19
                        tt19 = tt19 + CInt(montant)
                    Case Is = 20
                        tt20 = tt20 + CInt(montant)
                    Case Is = 21
                        tt21 = tt21 + CInt(montant)
                    Case Is = 22
                        tt22 = tt22 + CInt(montant)
                    Case Is = 23
                        tt23 = tt23 + CInt(montant)
                    Case Is = 24
                        tt24 = tt24 + CInt(montant)
                End Select
            If Year(Cells(i, 2).Value) = 2017 Then
                Select Case Mois
                    Case Is = 25
                        tt25 = tt25 + CInt(montant)
                    Case Is = 26
                        tt26 = tt26 + CInt(montant)
                    Case Is = 27
                        tt27 = tt27 + CInt(montant)
                    Case Is = 28
                        tt28 = tt28 + CInt(montant)
                    Case Is = 29
                        tt29 = tt29 + CInt(montant)
                    Case Is = 30
                        tt30 = tt30 + CInt(montant)
                    Case Is = 31
                        tt31 = tt31 + CInt(montant)
                    Case Is = 32
                        tt32 = tt32 + CInt(montant)
                    Case Is = 33
                        tt33 = tt33 + CInt(montant)
                    Case Is = 34
                        tt34 = tt34 + CInt(montant)
                    Case Is = 35
                        tt35 = tt35 + CInt(montant)
                    Case Is = 36
                        tt36 = tt36 + CInt(montant)
                End Select
        Sheets("Feuil2").Cells(1, 2).Value = "janvier 2015"
        Sheets("Feuil2").Cells(1, 3).Value = tt1
        Sheets("Feuil2").Cells(2, 2).Value = "fevrier 2015"
        Sheets("Feuil2").Cells(2, 3).Value = tt2
        Sheets("Feuil2").Cells(3, 2).Value = "mars 2015"
        Sheets("Feuil2").Cells(3, 3).Value = tt3
        Sheets("Feuil2").Cells(4, 2).Value = "avril 2015"
        Sheets("Feuil2").Cells(4, 3).Value = tt4
        Sheets("Feuil2").Cells(5, 2).Value = "mai 2015"
        Sheets("Feuil2").Cells(5, 3).Value = tt5
        Sheets("Feuil2").Cells(6, 2).Value = "juin 2015"
        Sheets("Feuil2").Cells(6, 3).Value = tt6
        Sheets("Feuil2").Cells(7, 2).Value = "juil 2015"
        Sheets("Feuil2").Cells(7, 3).Value = tt7
        Sheets("Feuil2").Cells(8, 2).Value = "aout 2015"
        Sheets("Feuil2").Cells(8, 3).Value = tt8
        Sheets("Feuil2").Cells(9, 2).Value = "sept 2015"
        Sheets("Feuil2").Cells(9, 3).Value = tt9
        Sheets("Feuil2").Cells(10, 2).Value = "oct 2015"
        Sheets("Feuil2").Cells(10, 3).Value = tt10
        Sheets("Feuil2").Cells(11, 2).Value = "nov 2015"
        Sheets("Feuil2").Cells(11, 3).Value = tt11
        Sheets("Feuil2").Cells(12, 2).Value = "dec 2015"
        Sheets("Feuil2").Cells(12, 3).Value = tt12
        Sheets("Feuil2").Cells(13, 2).Value = "janvier 2016"
        Sheets("Feuil2").Cells(13, 3).Value = tt13
        Sheets("Feuil2").Cells(14, 2).Value = "fevrier 2016"
        Sheets("Feuil2").Cells(14, 3).Value = tt14
        Sheets("Feuil2").Cells(15, 2).Value = "mars 2016"
        Sheets("Feuil2").Cells(15, 3).Value = tt15
        Sheets("Feuil2").Cells(16, 2).Value = "avril 2016"
        Sheets("Feuil2").Cells(16, 3).Value = tt16
        Sheets("Feuil2").Cells(17, 2).Value = "mai 2016"
        Sheets("Feuil2").Cells(17, 3).Value = tt17
        Sheets("Feuil2").Cells(18, 2).Value = "juin 2016"
        Sheets("Feuil2").Cells(18, 3).Value = tt18
        Sheets("Feuil2").Cells(19, 2).Value = "juil 2016"
        Sheets("Feuil2").Cells(19, 3).Value = tt19
        Sheets("Feuil2").Cells(20, 2).Value = "aout 2016"
        Sheets("Feuil2").Cells(20, 3).Value = tt20
        Sheets("Feuil2").Cells(21, 2).Value = "sept 2016"
        Sheets("Feuil2").Cells(21, 3).Value = tt21
        Sheets("Feuil2").Cells(22, 2).Value = "oct 2016"
        Sheets("Feuil2").Cells(22, 3).Value = tt22
        Sheets("Feuil2").Cells(23, 2).Value = "nov 2016"
        Sheets("Feuil2").Cells(23, 3).Value = tt23
        Sheets("Feuil2").Cells(24, 2).Value = "dec 2016"
        Sheets("Feuil2").Cells(24, 3).Value = tt24
        'refaire la mm chose pour 2017
10classeur3.xlsm (27.28 Ko)
bonjour,
je n'ai pas de problème avec le fichier que tu as fourni. Tu as probablement modifié le nom de tes onglets dans le fichier qui pose problème.
non je fais exactement sur le mm fichier
Ici :
le point surligné est de trop.
Mais là :
c'est tout ce qui est surligné qui est de trop.
sa marche merci
Rechercher des sujets similaires à "erreur vba"
