Envoyer un courriel a partir d'un user form
r
Bonjour ,
j'essaye d'envoyer un courriel a partir d'un userform . le corps de la lettre est chargé dans un fichier word que je selectionne avant apartir du user form (Send mail).
Voici l'erreur que j'arrive pas a corriger :
The Remote service Machine does not exit on this server
Set wdDoc = WApp.Documents.Open(wdFileName)Voici le code du module qui assure l'envoie du courriel a travers Outlook.
Sub CommandButton2_Click()
'Déclaration des variable
Dim wdDoc As Object
Dim wdFileName As Variant
Dim ws As Worksheet
Dim wb As Workbook
Dim WApp As Object
Dim OutApp As Outlook.Application
Dim OutMail As Outlook.MailItem
Dim VAR_Message As String
Dim VAR_Message_Eng As String
Dim VAR_Message_FR As String
Dim i As Integer
Dim Nbre_Line As Integer
Dim VAR_TO As String
Dim VAR_CC As String
Dim VAR_BCC As String
Dim VAR_Subject As String
Dim VAR_Beginning As String
Dim VAR_End As String
Dim ABody As String
Dim signature As String
wdFileName = sendmail.TextBox1.Value
' Set wb = ThisWorkbook
'Set ws = wb.Sheets("Process Info")
Set WApp = CreateObject("Word.Application")
If wdFileName = False Then Exit Sub
With wdDoc
'Condition pour la qualification
If Calendar_SLE.TextBox3.Text Like "?*@?*.?*" Then
VAR_Message_FR = "<b>" & wdDoc.Tables(1).Cell(1, 0).Range & "</b>" & "<br/>" & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(2, 0).Range & "</b>" & "<br/>" & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(3, 0).Range & "</b>" & "<br/>" _
& "<b>" & wdDoc.Tables(1).Cell(4, 0).Range & "</b>" & "<br/>"
VAR_Message = VAR_Message_FR
Set OutApp = CreateObject("outlook.application")
Set OutMail = OutApp.CreateItem(olMailItem)
With OutMail
.display
signature = OutMail.HTMLBody
'Setting of Email
VAR_TO = Calendar_SLE.TextBox1.Text
VAR_CC = ""
VAR_BCC = ""
VAR_Subject = ""
VAR_Beginning = ""
VAR_End = ""
ABody = VAR_Message
With OutMail
.To = VAR_TO
.CC = VAR_CC
.BCC = VAR_BCC
.Subject = VAR_Subject
.HTMLBody = ABody & signature
.display
'.Save
'.Send
On Error GoTo 0
Set OutMail = Nothing
Set OutApp = Nothing
MsgBox ("Email non Valide")
'Close the Word document with saving
wdDoc.Close False
Set wdDoc = Nothing
'wdFileName = Dir
End SubMerci
