Bonjour fanfan38,
Votre solution est impeccable,
Maintenant, je souhaiterais y ajouter la gestion de doublons du champ ID_Etal ,
Ensuite trouver le code de la commande MODIFIER et SUPPRIMER.
Private OP As Worksheet
Private Sub CmdENREGISTRER_Click()
'_____________________________________________________________
Dim rep As Byte
rep = MsgBox("Voulez vous enregistrer " & vbCrLf & _
"les modifications effectuées ?", vbOKCancel)
If rep <> 1 Then Exit Sub
'______________________________________________________________
'"& vbCrLf & "
If Me.TextBoxID_Etabl = "" Or Me.TextBoxNomEtablissement = "" _
Or Me.TextBoxNomARABE_Etabl = "" Or Me.TextBoxCode_Prive = "" _
Or Me.TextBoxAutres_Infos = "" Or Me.TextBoxId_AdresseEtab = "" _
Or Me.TextBoxObservations = "" Then
MsgBox "Vous n'avez pas renseigné tous les champs", vbInformation, "Saisie manquante"
Exit Sub
If Not IsDate(TextBoxDateEnregistrement.Value) Then
MsgBox "Attention, saisissez une date de réception en respectant le format JJ/MM/AAAA.", vbExclamation, "Saisie manquante"
TextBoxNomEtablissement.SetFocus
Exit Sub
Dim n As Long
Set OP = Sheets("EtablissementScolaire_Service")
ActiveSheet.Unprotect Password:="oumar"
If [T_etabl].Item(1, 1) <> "" Then n = [T_etabl].Rows.Count + 1 Else n = 1
[T_etabl].Item(n, 1) = "xxxx"
[T_etabl].Item(n, 1) = Val(TextBoxID_Etabl.Value)
[T_etabl].Item(n, 2) = TextBoxNomEtablissement.Value
[T_etabl].Item(n, 6) = TextBoxNomARABE_Etabl.Value
[T_etabl].Item(n, 4) = Val(TextBoxId_AdresseEtab.Value)
[T_etabl].Item(n, 5) = TextBoxAutres_Infos.Value
[T_etabl].Item(n, 7) = TextBoxCode_Prive.Value
[T_etabl].Item(n, 8) = TextBoxObservations.Value
[T_etabl].Item(n, 3) = CDate(TextBoxDateEnregistrement.Value)
OP.Protect Password:="oumar", UserInterfaceOnly:=True
ActiveWorkbook.Protect Password:="oumar" ', UserInterfaceOnly:=True
Unload Me
