Sub initialise_Fiche_convoi()
' initialise_fiche_convoi Macro
Range("B4:E17,B19:E32").Select
Range("B19").Activate
ActiveWindow.SmallScroll Down:=24
Range("B4:E17,B19:E32,B34:E47").Select
Range("B34").Activate
ActiveWindow.SmallScroll Down:=18
Range("B4:E17,B19:E32,B34:E47,B49:E49,B51:E64").Select
Range("B51").Activate
ActiveWindow.SmallScroll Down:=15
Range("B4:E17,B19:E32,B34:E47,B49:E49,B51:E64,B66:E79").Select
Range("B66").Activate
Range("B4:E17,B19:E32,B34:E47,B49:E49,B51:E64,B66:E79,B81:E96").Select
Range("B81").Activate
Range("B4:E17,B19:E32,B34:E47,B49:E49,B51:E64,B66:E79,B81:E96,B98:E111").Select
Range("B98").Activate
ActiveWindow.SmallScroll Down:=9
Range( _
"B4:E17,B19:E32,B34:E47,B49:E49,B51:E64,B66:E79,B81:E96,B98:E111,B113:E126"). _
Select
Range("B113").Activate
Range( _
"B4:E17,B19:E32,B34:E47,B49:E49,B51:E64,B66:E79,B81:E96,B98:E111,B113:E126,B128:E143" _
).Select
Range("B128").Activate
ActiveWindow.SmallScroll Down:=6
Range( _
"B4:E17,B19:E32,B34:E47,B49:E49,B51:E64,B66:E79,B81:E96,B98:E111,B113:E126,B128:E143,B145:E158" _
).Select
Range("B145").Activate
Selection.ClearContents
Voici la macro que je souhaite faire mettre en place
Stop,
sa fonctionne erreur de ma part
Merci cousinhuB
