Créer multiple graphique VBA
Bonjour, je cherche un moyen de créer plusieurs graphiques avec une boucle for. Merci d'avance
voici le code que j'utilise, il ne prend pas le graph(i) ;
For i = 1 To nb
    Dim grap As ChartObject
    Dim graph As Chart
    Set grap(i) = Sheets("Duty cycle graph cycle ").ChartObjects.Add(Range("Q2").Offset(0, 30 * (i - 1)).Left, Range("Q2").Offset(0, 30 * (i - 1)).Top, 800, 400)
    Set graph(i) = grap.Chart
    With graph(i)
       .HasTitle = True
       .HasLegend = True
       .ChartTitle.Text = "Hauteur des chevrons selon les différents caoutchouc " & Sheets("Étape 9-chevrons").Range("b5").Offset(0, i)
       .Axes(xlValue).HasTitle = True
       .Axes(xlValue).AxisTitle.Text = "hauteur (pouce)"
       .Axes(xlCategory).HasTitle = True
       .Axes(xlCategory).AxisTitle.Text = "endroit de la chenille"
       Set xx = Sheets("Étape 9-chevrons").Range("B9:b18")
       For j = 1 To 6
              Set yy = Sheets("Étape 9-chevrons").Range("c9:c18").Offset(9 * (j - 1), 0)
        graph(i).SeriesCollection.NewSeries
                graph(i).SeriesCollection(j).Name = Sheets("Étape 9-chevrons").Range("AJ8").Offset(j, 0)
                graph(i).SeriesCollection(j).XValues = xx
                graph(i).SeriesCollection(j).Values = yy
                graph(i).SeriesCollection(j).ChartType = xlLineMarkers
                Next j
essaie ainsi :
Public Sub Create_charts()
Dim wsChart As Worksheet, wsData As Worksheet
Dim objChart As ChartObject
Dim strTitle As String
Dim rCell As Range, X_axis As Range, Y_axis As Range
Dim i As Long, j As Long
    Set wsChart = Worksheets("Duty cycle graph cycle")
    Set wsData = Worksheets("?tape 9-chevrons")
    For Each objChart In wsChart.ChartObjects
        objChart.Delete
    Next objChart
    Set X_axis = wsData.Range("B9:B18")
    For i = 1 To 4
        strTitle = wsData.Cells(5, 2).Offset(, i)
        Set rCell = wsChart.Cells(2, 17).Offset(, 30 * (i - 1))
        Set objChart = wsChart.ChartObjects.Add(rCell.Left, rCell.Top, 800, 400)
        objChart.Name = "Chart_" & i
        With objChart.Chart
            .HasTitle = True
            .HasLegend = True
            .ChartTitle.Text = "Hauteur des chevrons selon les diff?rents caoutchouc " & strTitle
            .Axes(xlValue).AxisTitle.Text = "Hauteur (pouce)"
            .Axes(xlCategory).AxisTitle.Text = "Endroit de la chenille"
            For j = 1 To 6
                Set Y_axis = wsData.Range("C9:C18").Offset(9 * (j - 1))
                .SeriesCollection(j).Name = wsData.Cells(8, 36).Offset(j, 0)
                .SeriesCollection(j).XValues = X_axis
                .SeriesCollection(j).Values = Y_axis
            Next j
            strTitle = ""
essaie ainsi :
        objChart.Delete
    Next objChart
    For i = 1 To 4
        With objChart.Chart
            .HasTitle = True
            .HasLegend = True
            For j = 1 To 6
            Next j
            strTitle = ""
Ça l'a fonctionné, un gros merci !
Rechercher des sujets similaires à "creer multiple graphique vba"
