Création d'un code VBA en appuyant sur un bouton
Bonjour je suis bloqué sur mon code vba. Quand j'appuie sur le bouton, j'aimerai que le code se lance 2 ligne en dessous du in entrer:
Sub Test()
Application.Range("A2").Value = "New run"
Application.Range("A3").Value = "Lap"
Application.Range("A4").Value = "1"
Application.Range("B4").Value = "out"
Application.Range("B3").Value = "Time"
Application.Range("D3").Value = "Type"
Application.Range("E3").Value = "Rotation"
Application.Range("F3").Value = "Refuel"
Application.Range("G3").Value = "Arbf"
Application.Range("H3").Value = "Arbr"
Application.Range("I3").Value = "Front wing"
Application.Range("J3").Value = "Rear wing"
Application.Range("K3").Value = "Coment"
Range("E4").Select
With Selection.Validation
.Delete
.Add Type:=xlValidateList, AlertStyle:=xlValidAlertStop, Operator:= _
xlBetween, Formula1:="=info!$A$2:$A$3"
.IgnoreBlank = True
.InCellDropdown = True
.InputTitle = ""
.ErrorTitle = ""
.InputMessage = ""
.ErrorMessage = ""
.ShowInput = True
.ShowError = True
Range("G4").Select
.Delete
xlBetween, Formula1:="=info!$B$2:$B$5"
.IgnoreBlank = True
.InputTitle = ""
.ErrorTitle = ""
.InputMessage = ""
.ErrorMessage = ""
.ShowInput = True
.ShowError = True
Range("H4").Select
.Delete
xlBetween, Formula1:="=Info!$C$2:$C$5"
.IgnoreBlank = True
.InputTitle = ""
.ErrorTitle = ""
.InputMessage = ""
.ErrorMessage = ""
.ShowInput = True
.ShowError = True
Range("I3:I1048576").Select
Selection.FormatConditions.Add Type:=xlCellValue, Operator:=xlNotBetween, _
Formula1:="=-3,5", Formula2:="=1,5"
Selection.FormatConditions(Selection.FormatConditions.Count).SetFirstPriority
With Selection.FormatConditions(1).Interior
.PatternColorIndex = xlAutomatic
.Color = 10066431
.TintAndShade = 0
Selection.FormatConditions(1).StopIfTrue = False
Selection.FormatConditions.Add Type:=xlTextString, String:="Front wing", _
TextOperator:=xlContains
.ThemeColor = xlThemeColorDark1
.TintAndShade = 0
Range("J3:J1048576").Select
Formula1:="=0", Formula2:="=15"
.Color = 10066431
.TintAndShade = 0
Selection.FormatConditions.Add Type:=xlTextString, String:="Rear wing", _
.TintAndShade = 0
Columns("B:B").Select
Selection.FormatConditions.Add Type:=xlCellValue, Operator:=xlEqual, _
Formula1:="=MIN(B:B)"
.Color = 10498160
.TintAndShade = 0
ActiveSheet.Buttons.Add(595.5, 32.25, 222.75, 43.5).Select
Selection.OnAction = "Sheet6.Test"
Range("N8").Select
je comprends déjà pas la question : " j'aimerai que le code se lance 2 ligne en dessous du in entrer:"
c'est pas vraiment trois pages de codes qui vont résoudre la question.
un fichier exemple serait d'avantage explicite.
Si en traduction tu souhaites que ton bouton ne lance qu'une partie de cette macro ? alors tu copies la partie que que souhaites dans un autres "sub"
que tu affecte à ton bouton
Voici un peu prés se que j'ai fait et j'aimerai que quand j'appuis sur le bouton sa réécrive se que j'ai fait mais deux ligne en dessous le in, avec une boucle while.
18erwan-stage2.xlsm (47.66 Ko)
Rechercher des sujets similaires à "creation code vba appuyant bouton"
