COUNTIF number of occurrences of numerical value < threshold
Hello
I am trying to count number of times a number - in a text format - is below a given threshold. It happens that is the range, there are non-numerical values as in below example
- In B1, the formula "=--(VALUE(A1:A4))" is to convert A1:A4 into numerical value, shown in Excel as { 10, 20, #VALUE!, 30 }
- In C1, the formula "=--(B1:B4)<30" is to an array of boolean, here { TRUE, TRUE, #VALUE!, FALSE }
- In E1, the formula "=COUNTIF(C1#;TRUE)" gives the result 2
The issue I have is that I don't know how to combine formulas of B1, B2 and E1 in a single formula... Any idea?
ABCEF
110=--(VALUE(A1:A4))=--(B1:B4)<30=COUNTIF(C1#;TRUE)
220
3A
430
Thanks a lot for your help,
stchln
Hello Stchln, hello forum,
Did you know that google has a tool called "Google translator"?
Example:
Bonjour Stchln, bonjour le forum,
Sais-tu que google possède un outil nommé "Google traducteur" ?
Hi stchin, salut ThauThème
Ne soyons pas chauvin
In French the formula is :
=SOMMEPROD(ESTNUM(CNUM(A1:A4))*1)
In English may be
=SUMPRODUCT(ISNUMBER(VALUE(A1:A4))*1)
Hi BrunoM45
Thanks for your response. This sounds promising but not yet what I need. I think we need also a test vs the threshold 30
stchln
With custom function In VBA
Function CountNumberText(Rng As Range, Max As Integer)
  Dim Cel As Range, Ind As Integer
  ' Execute every time
  Application.Volatile
  ' Initialise
  Ind = 0
  For Each Cel In Rng
    If IsNumeric(Cel) And Val(Cel) < Max Then
      Ind = Ind + 1
  Next Cel
  ' Return result
  CountNumberText = Ind
End Function
To Call
=CountNumberText(A1:A4;30)
merci beaucoup BrunoM45, je vais donc me résoudre à faire du VBA, à copier ce que vous avez bien voulu partager. Encore Merci
stchln
sinon, pour partager, inspiré par vous, j’ai trouvé une possibilité ci-dessous
={SUMPRODUCT(--IFERROR(VALUE(A1:A4)<30;0))}
In French
={SOMMEPROD(--SIERREUR(CNUM(A1:A4)<30;0))}
stchln
Pour moi, le résultat n'est pas correcte
Retourne 1 pour l'exemple alors que ce devrait être 2
bizarre, ça fonctionne pour moi
voir fichier attaché, formule en E1 "=SUMPRODUCT(--IFERROR(VALUE(A1:A4)<30;0))"
15book1.xlsx (10.53 Ko)
Bonjour stchIn
je comprends mieux,
Tu n'as pas indiqué la formule correctement, c'est un produit matriciel entouré d'accolade
C'est corrigé
ok, merci encore pour l’aide
Rechercher des sujets similaires à "countif number occurrences numerical value threshold"
