Couleurs colonnes pour mise en forme
Suite à une question posée hier sur un programme, je voudrai aujourd'hui pouvoir faire une mise en forme plus sympa pour une présentation.
Voici le code de mon programme :
Sub RéorgTablo()
Dim d As Object, T(), k, itm, n%, i%, j%, v%, w%
Set d = CreateObject("Scripting.Dictionary")
With Worksheets("Board")
n = .Cells(.Rows.Count, 1).End(xlUp).Row
For i = 4 To n
If InStr(.Cells(i, 6), Chr(10)) > 0 Then
k = Split(.Cells(i, 6), Chr(10))
For j = 0 To UBound(k)
If d.exists(k(j)) Then
d(k(j)) = d(k(j)) & ";" & .Cells(i, 1) & ";" & .Cells(i, 4)
d(k(j)) = .Cells(i, 1) & ";" & .Cells(i, 4)
v = UBound(Split(d(k(j)), ";"))
If v > w Then w = v
Next j
k = .Cells(i, 6)
If d.exists(k) Then
d(k) = d(k) & ";" & .Cells(i, 1) & ";" & .Cells(i, 4)
d(k) = .Cells(i, 1) & ";" & .Cells(i, 4)
v = UBound(Split(d(k), ";"))
If v > w Then w = v
ReDim T(d.Count, w + 1): n = 0
For Each k In d.keys
n = n + 1: T(n, 0) = k
itm = Split(d(k), ";")
For i = 0 To UBound(itm)
T(n, i + 1) = itm(i)
Next k
T(0, 0) = "Part Number": v = 0
For i = 1 To w + 1 Step 2
v = v + 1: T(0, i) = "N°" & v: T(0, i + 1) = "Idea " & v
With Worksheets("Part Number").Range("A1")
With .CurrentRegion
.ClearContents
.Interior.ColorIndex = xlColorIndexNone
.Borders.LineStyle = xlLineStyleNone
With .Resize(UBound(T, 1) + 1, UBound(T, 2) + 1)
.Value = T
With .Borders
.LineStyle = xlContinuous: Weight = xlThin
[color=#FF0000] .Rows(1).Interior.Color = RGB(50, 50, 50) 'Couleur première ligne'
.Rows(1).Font.Color = RGB(255, 255, 255) 'Couleur texte première ligne'
.Range("A2:A92").Interior.Color = RGB(217, 217, 217)
.Range("B2:B92").Interior.Color = RGB(230, 230, 230)
.Range("D2:D92").Interior.Color = RGB(230, 230, 230)
.Range("F2:F92").Interior.Color = RGB(230, 230, 230)
.Range("H2:H92").Interior.Color = RGB(230, 230, 230)
.Range("J2:J92").Interior.Color = RGB(230, 230, 230)
.Range("L2:L92").Interior.Color = RGB(230, 230, 230)
.Range("N2:N92").Interior.Color = RGB(230, 230, 230)
.Range("P2:P92").Interior.Color = RGB(230, 230, 230)[/color]
.Worksheet.Activate
End SubJ'aimerai automatiser la partie en rouge pour qu'une colonne sur 2 soit grise mais que sur les colonnes ou il y a du texte. Et j'aimerai aussi que le nombre de ligne s'automatise, en partant de la seconde jusqu'à la dernière remplie.
Je met un petit Excel témoin pour montrer ce que je voudrai.
FloBru
Merci beaucoup, ca fonctionne bien pour la mise en page, merci mais il me faut tester si d'autres colonnes s'ajoutent si ca fonctionne.
En tout cas merci beaucoup
FloBru
si la colonne "touche" le reste du tableau, alors elle sera automatiquement intégrée au tableau est elle "subira" le même type de traitement au niveau des mise en formes.
@ bientôt
LouReeD
