Copier .txt to worksheet et forcer format texte
après plusieurs heures d'essai, je me retrouve avec la macro suivante fonctionnelle :
Sub TxtMAJ()
    Dim path As String, feuilles As String, feuil, f As Long
    Dim wbExcel As Workbook, wbText As Workbook
    Dim wsExce1l As Worksheet
    Set wbExcel = ThisWorkbook 'specify here which Excel file the text file’s content is to be pasted into
    Set wsExcel1 = wbExcel.Sheets("blk") 'specify here which worksheet to use
    Set wbText1 = Workbooks.Open("C:\xxx\blk.txt")
    feuilles = "blk;bs"
    wbText1.Sheets("blk").Cells.Copy wsExcel1.Cells
    wbText1.Close SaveChanges:=False
    Sheets("blk").Select
    Rows("1:1").Select
    Selection.AutoFilter
    ActiveWorkbook.Worksheets("blk").AutoFilter.Sort.SortFields.Clear
    ActiveWorkbook.Worksheets("blk").AutoFilter.Sort.SortFields.Add2 Key:=Range( _
        "K1"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
    With ActiveWorkbook.Worksheets("blk").AutoFilter.Sort
        .Header = xlYes
        .MatchCase = False
        .Orientation = xlTopToBottom
        .SortMethod = xlPinYin
        .Apply
    ActiveWorkbook.Worksheets("blk").AutoFilter.Sort.SortFields.Add(Range("Q1"), _
        xlSortOnCellColor, xlAscending, , xlSortNormal).SortOnValue.Color = RGB(255, _
        255, 0)
        .Header = xlYes
        .MatchCase = False
        .Apply
    Columns("AA:AD").Select
    Selection.ClearContents
    Set wsExcel2 = wbExcel.Sheets("bs") 'specify here which worksheet to use
    Set wbText2 = Workbooks.Open("C:\xxx\bs.txt")
    wbText2.Sheets("bs").Cells.Copy wsExcel2.Cells
    wbText2.Close SaveChanges:=False
     Sheets("bs").Select
    Rows("1:1").Select
    ActiveWorkbook.Worksheets("bs").AutoFilter.Sort.SortFields.Clear
    ActiveWorkbook.Worksheets("bs").AutoFilter.Sort.SortFields.Add2 Key:=Range( _
        "L1"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
    With ActiveWorkbook.Worksheets("bs").AutoFilter.Sort
        .Header = xlYes
        .MatchCase = False
        .Apply
    ActiveWorkbook.Worksheets("bs").AutoFilter.Sort.SortFields.Add(Range("Q1"), _
        255, 0)
        .Header = xlYes
        .MatchCase = False
        .Apply
    feuil = Split(feuilles, ";")
    For f = 0 To UBound(feuil)
        Worksheets(feuil(f)).Copy
        With Worksheets(1)
            path = "C:\xxx\Imports Cargo\"
            ActiveWorkbook.SaveAs Filename:=path & LCase(feuil(f)) & ".txt", FileFormat:=xlText
            ActiveWorkbook.Close SaveChanges:=False
    Next f
        With Worksheets(1)
            path = "C:\xxx\Imports WinExpe\"
    Next f
Le problème est le suivant : les fichier .txt (blk.txt et bs.txt) sont bien copiés vers mes feuilles excel du même nom puis triée mais le format "standard" est appliqué,
or, j'ai besoin de forcer le format de collage "texte" pour ne pas me retrouver avec des infos du type "4,22226E+13" mais bien "42222594792867".
Voila, je pense que c'est clair, merci pour votre aide car je sèche..!
Bonne fin de WE à tous,
Balek
bonjour,
With Worksheets(1)
.Cells.NumberFormat = "#,##0" '<-----------------------------------------------
Path = "C:\xxx\Imports WinExpe\"
ActiveWorkbook.SaveAs Filename:=Path & LCase(feuil(f)) & ".txt", FileFormat:=xlText
Merci mais non, je me retrouve avec des infos du style ""32,965,671,405,883"", il y a des " et des , en trop dans les .txt finaux...
c'est bon j'ai trouvé, il suffisait de transformer .Cells.NumberFormat = "#,##0" en .Cells.NumberFormat = "###0" en ça fonctionne parfaitement, merci !
Finalement ça ne fonctionne pas parfaitement... en effet, si les premiers caractères d'une colonne sont des "0", ils sautent lors de la macro (cf. Fichier avant traitement et fichier après traitement).
19entree.txt (795.00 Octets)
26sortie.txt (797.00 Octets)
Vous pouvez constater que le premier "0" de la 2eme colonne ainsi que le premier "0" de la colonne code postal ont disparus.
Quelqu'un à une idée de pourquoi ? et de comment régler le problème ?
Merci par avance,
Balek
Up !
Merci par avance,
Balek
Rechercher des sujets similaires à "copier txt worksheet forcer format texte"
