Convertir en date plusieurs colonnes
Bonjour le forum
Je souhaite convertir en dates le contenu des colonnes : G, H, I, L, Q, AB, AC, AD et AE
Mais mon code ne fonctionne pas cad les colonnes ne sont pas en date.
Désolée pour la longueur, ça va piquer les yeux des puristes
19test.xlsx (9.31 Ko)
sub test
    LastRow = OngletBase.Cells(OngletBase.Rows.Count, "A").End(xlUp).Row
    For i = 2 To LastRow
        If OngletBase.Range("G" & i).Value <> "" And IsDate(OngletBase.Range("G" & i).Value) = False Then
            OngletBase.Range("G" & i).Value = DateValue(OngletBase.Range("G" & i).Value)
        If OngletBase.Range("H" & i).Value <> "" And IsDate(OngletBase.Range("H" & i).Value) = False Then
            OngletBase.Range("H" & i).Value = DateValue(OngletBase.Range("H" & i).Value)
        If OngletBase.Range("I" & i).Value <> "" And IsDate(OngletBase.Range("I" & i).Value) = False Then
            OngletBase.Range("I" & i).Value = DateValue(OngletBase.Range("I" & i).Value)
        If OngletBase.Range("L" & i).Value <> "" And IsDate(OngletBase.Range("L" & i).Value) = False Then
            OngletBase.Range("L" & i).Value = DateValue(OngletBase.Range("L" & i).Value)
        If OngletBase.Range("Q" & i).Value <> "" And IsDate(OngletBase.Range("Q" & i).Value) = False Then
            OngletBase.Range("Q" & i).Value = DateValue(OngletBase.Range("Q" & i).Value)
        If OngletBase.Range("AB" & i).Value <> "" And IsDate(OngletBase.Range("AB" & i).Value) = False Then
            OngletBase.Range("AB" & i).Value = DateValue(OngletBase.Range("AB" & i).Value)
        If OngletBase.Range("AC" & i).Value <> "" And IsDate(OngletBase.Range("AC" & i).Value) = False Then
            OngletBase.Range("AC" & i).Value = DateValue(OngletBase.Range("AC" & i).Value)
        If OngletBase.Range("AD" & i).Value <> "" And IsDate(OngletBase.Range("AD" & i).Value) = False Then
            OngletBase.Range("AD" & i).Value = DateValue(OngletBase.Range("AD" & i).Value)
        If OngletBase.Range("AE" & i).Value <> "" And IsDate(OngletBase.Range("AE" & i).Value) = False Then
            OngletBase.Range("AE" & i).Value = DateValue(OngletBase.Range("AE" & i).Value)
end sub
Ci joint ma solution
18test.xlsm (20.05 Ko)
A+ François
bonjour fopinem,
Sub Convertir()
     For Each col In Array("L", "Q", "AB", "AC", "AD")
          With Sheets("feuil1").Columns(col)
               .TextToColumns Destination:=.Range("A1"), DataType:=xlDelimited, TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=False, Tab:=False, Semicolon:=False, Comma:=False, Space:=False, Other:=False, FieldInfo:=IIf(col = "Q", Array(1, 5), Array(1, 4)), TrailingMinusNumbers:=True
               .AutoFit
EDIT : salut fanfan38
Rechercher des sujets similaires à "convertir date colonnes"
