Bonsoir à tous est-il possible d'organiser ce code de façon à le réduire et éviter cette répétition.
Merci pour vos suggestions.
Bonne soirée
If Not Intersect(Target, Range("Q8:Q27")) Is Nothing Then
If Range("Q8") = "1" Then
Range("R8") = Range("P8")
Range("R8") = ""
If Range("Q9") = "1" Then
Range("R9") = Range("P9")
Range("R9") = ""
If Range("Q10") = "1" Then
Range("R10") = Range("P10")
Range("R10") = ""
If Range("Q11") = "1" Then
Range("R11") = Range("P11")
Range("R11") = ""
If Range("Q12") = "1" Then
Range("R12") = Range("P12")
Range("R12") = ""
If Range("Q13") = "1" Then
Range("R13") = Range("P13")
Range("R13") = ""
If Range("Q14") = "1" Then
Range("R14") = Range("P14")
Range("R14") = ""
If Range("Q15") = "1" Then
Range("R15") = Range("P15")
Range("R15") = ""
If Range("Q16") = "1" Then
Range("R16") = Range("P16")
Range("R16") = ""
If Range("Q17") = "1" Then
Range("R17") = Range("P17")
Range("R17") = ""
If Range("Q18") = "1" Then
Range("R18") = Range("P18")
Range("R18") = ""
If Range("Q19") = "1" Then
Range("R19") = Range("P19")
Range("R19") = ""
If Range("Q20") = "1" Then
Range("R20") = Range("P20")
Range("R20") = ""
If Range("Q21") = "1" Then
Range("R21") = Range("P21")
Range("R21") = ""
