Comment on userform
Hello Guys,
plz need your help, i wanna show a comment when i cross a textBox, ComboBox or ... in a userform. How would i do that ?
Thank you it is urgent
Hi,
I'm not sure I completely understand what you need. Do you simply wish to add a comment to a cell that indicates what user it was left by?
Thanks.
thanks for answering, but what i need is to show a comment wish explain smth about the cell so that the user doesn't write smth wrong.
For exemple if my cell has to have a number% btw (2% to 4%) the user has to write a number in btw. and the message will be when i cross that cell " the rate of bla bla is btw 2% and 4% "
Ok, look at the sample excel sheet I attached. If you scroll over the yellow squares, you'll see a comment box pop up. Is this what you are referring to?
682comments.zip (4.10 Ko)
yes exactly what i need but in a textbox or comboBox in a userform thank you
Here is what I was able to find. I have Excel 2010 so it isn't exactly like 2007. But this should help.
http://www.youtube.com/watch?v=AWWKAWttuiU
oh this video is not about adding comment anyway i found the solution u have to use this method
Private Sub Userform_Activate()
TextBox1.ControlTipText = "bla bla bla"
end sub
This is the code of how it works.
Thank you Brother
You're welcome Sister.
Rechercher des sujets similaires à "comment userform"
