Attribution Image.Picture
Bonsoir à tous,
J'essai d'attribuer à l'image1 de mon userform une image présente dans mon dossier "Trombinoscope". Dans mon projet final, le dossier "trombinoscope" comporte des sous dossiers donc mon code commence par lister sur la "Feuil1 les noms des images présentes, pour ensuite attribuer l'image dont le nom est en cellule A1 à l'image1 mais c'est là que ça bloque : objet requis
Voici mon code... Si quelqu'un peut me renseigner sur mon erreur
    Dim myPath As String
    Dim myFile As String
    Dim FSO As Object
    Dim doss As Object
    Dim Mag As String
    Dim IM1 As String
    Sheets("Feuil1").Activate
    myPath = ThisWorkbook.Path
    myFile = Dir(myPath & "\Trombinoscope" & "\*.jpg")
    c = 1
    Do While myFile <> ""
    Cells(c, 1) = myFile
    myFile = Dir()
    c = c + 1
    Loop
    Set FSO = CreateObject("scripting.Filesystemobject")
    Set doss = FSO.getfolder(ThisWorkbook.Path & "\Trombinoscope\" & Mag)
    MsgBox doss.Files.count
    If doss.Files.count = 1 Then USFTrombino.Height = 243: USFTrombino.Width = 484: Label5.Left = 66
    If doss.Files.count = 2 Then USFTrombino.Height = 243: USFTrombino.Width = 390: Label5.Left = 18
    If doss.Files.count = 3 Then USFTrombino.Height = 243: USFTrombino.Width = 484: Label5.Left = 66
    If doss.Files.count = 4 Then USFTrombino.Height = 243: USFTrombino.Width = 390: Label5.Left = 18
    If doss.Files.count = 5 Then USFTrombino.Height = 243: USFTrombino.Width = 484: Label5.Left = 66
    If doss.Files.count = 6 Then USFTrombino.Height = 243: USFTrombino.Width = 578: Label5.Left = 113
    If doss.Files.count = 7 Then USFTrombino.Height = 393: USFTrombino.Width = 484: Label5.Left = 66
    If doss.Files.count = 8 Then USFTrombino.Height = 393: USFTrombino.Width = 484: Label5.Left = 66
    If doss.Files.count = 9 Then USFTrombino.Height = 393: USFTrombino.Width = 484: Label5.Left = 66
    If doss.Files.count = 10 Then USFTrombino.Height = 393: USFTrombino.Width = 484: Label5.Left = 66
    If doss.Files.count = 11 Then USFTrombino.Height = 393: USFTrombino.Width = 578: Label5.Left = 113
    If doss.Files.count = 12 Then USFTrombino.Height = 393: USFTrombino.Width = 578: Label5.Left = 113
    If doss.Files.count = 13 Then USFTrombino.Height = 393: USFTrombino.Width = 673: Label5.Left = 160
    If doss.Files.count = 14 Then USFTrombino.Height = 393: USFTrombino.Width = 673: Label5.Left = 160
    Image1.Picture = ThisWorkbook.Path & "\Trombinoscope\" & Sheets("Feuil1").Range("A1").Value
Set FSO = Nothing
Set doss = Nothing
33test.zip (794.05 Ko)
Pb syntaxe !
Charger un fichier image pour l'affecter à la propriété Picture d'un contrôle Image :
... = LoadPicture(fichier)
Merci beaucoup
Rechercher des sujets similaires à "attribution image picture"
