re,
Merci m3ellem1,
voici une nouvelle version pour modifier tous les fichier.txt d'un répertoire,
ps / sans l'utilisation d'une feuille
'ajouter la référence Microsoft Scripting Runtime
Sub test3()
Dim oFSO As Scripting.FileSystemObject
Dim oFl As Scripting.file
Dim oTxt As Scripting.TextStream
Dim oFile, sfoFolder
Dim s, i As Long, rw As Long, n As Integer, t As String, Var As String, Nouveufichier As String
Dim tbl()
Set oFSO = New Scripting.FileSystemObject
Set sfoFolder = oFSO.GetFolder("C:\Users\isabelle\Documents\Test11") '<--répertoire à adapter
For Each oFile In sfoFolder.Files
If LCase(Right(oFile, 4)) = ".txt" Then
Set oFl = oFSO.GetFile(oFile)
Set oTxt = oFl.OpenAsTextStream(ForReading)
s = Split(oFile, ".")
Nouveufichier = s(0) & "(corr).txt"
rw = 0
While Not oTxt.AtEndOfStream
rw = rw + 1
ReDim Preserve tbl(rw)
tbl(rw) = oTxt.ReadLine
Wend
Set oTxt = oFSO.CreateTextFile(Nouveufichier)
For i = LBound(tbl) To UBound(tbl)
If i = 1 Then Var = "Temps" Else Var = "00:00:01"
s = Split(tbl(i), Chr(9))
For n = LBound(s) To UBound(s)
Select Case n
Case 1: t = t & s(n) & Chr(9) & Var & Chr(9)
Case Else: t = t & s(n) & Chr(9)
End Select
Next n
oTxt.WriteLine t
t = ""
Next oFile
