Afficher image avec .htmlbody en VBA hors outlook
je donne ma langue au chat...
j'ai utilise le code suivant :
 Private Sub CommandButton101_Click()
 Dim Ws As Worksheet
 Dim ob As Object
 Dim Pieces, Adresse, ClasseurActif
 Dim OL As Object
 Dim OLmail As Object
 Dim Texte As String
 Sheets("contact").Select
 totalcontact = 1
 Do
 totalcontact = totalcontact + 1
 Loop Until (Range("A" & totalcontact) = "")
 progression = 0
 nbcontact = 1
 Do
 nbcontact = nbcontact + 1
 labelprogession = nbcontact / totalcontact * 100
 progression = 200 * labelprogession / 100
 prenom = Sheets("contact").Range("A" & nbcontact).Value
 Nom = Sheets("contact").Range("B" & nbcontact).Value
 Adresse = Sheets("contact").Range("C" & nbcontact).Value
 Image_barre.Width = progression
 Label_barre.Caption = labelprogession & "%"
 DoEvents
 'envoi du mail
 On Error Resume Next
Set OL = CreateObject("Outlook.Application") Set OLmail = OL.CreateItem(olMailItem) '0
 'enléve les messages d'alerte
 'remet les messages d'alerte
 'réactive le rafraichissement de l'écran
 ' Adresse = "xxxxxxxxxxxxxxxxx@gmail.com" 'pour exemple
 With OLmail
 .From = "xxxxxxxxxxxx@hotmail.com"
 .To = Adresse
 .BodyFormat = olFormatHTML
 .Subject = "HMTL BODY du " & Date
 ' debut du message html
 Const SAUTLIGNE = "<br/>"
 .HTMLBody = "<body>"
 img1 = "1-4.jpg"
 img2 = "2-4.jpg"
 img3 = "3-4.jpg"
 img4 = "4-4.jpg"
 .Attachments.Add ThisWorkbook.Path & "\" & "1-4.jpg", olByValue, 0
 .Attachments.Add ThisWorkbook.Path & "\" & "2-4.jpg", olByValue, 0
 .Attachments.Add ThisWorkbook.Path & "\" & "3-4.jpg", olByValue, 0
 .Attachments.Add ThisWorkbook.Path & "\" & "4-4.jpg", olByValue, 0
 'Ecrit bonjour en gras, calibri, taille 40
 .HTMLBody = .HTMLBody & "<font face=""calibri"" size =""40"" color=""black""> hello <b>Bonjour ! " & prenom & " " & Nom & "</b></font>"
 'Saute deux lignes
 .HTMLBody = .HTMLBody & SAUTLIGNE & SAUTLIGNE
 'Ecrit le reste de l'entete
 .HTMLBody = .HTMLBody & "<div align='center'><table>"
 .HTMLBody = .HTMLBody & "<tr>"
 .HTMLBody = .HTMLBody & "<td valign='middle'><b>test : <input type='text'>Ligne 1 - cols 1</input></b></td>"
 .HTMLBody = .HTMLBody & "<td valign='middle'><b><img src='" & img1 & "'>"
 .HTMLBody = .HTMLBody & "Ligne 1 - cols 2</b></td>"
 .HTMLBody = .HTMLBody & "<td valign='middle'><b><img src='" & img2 & "'>"
 .HTMLBody = .HTMLBody & "Ligne 1 - cols 3</b></td>"
 .HTMLBody = .HTMLBody & "</tr>"
 .HTMLBody = .HTMLBody & "<td valign='middle'><b><img src='" & img3 & "'>"
 .HTMLBody = .HTMLBody & "Ligne 2 - cols 1</b></td>"
 .HTMLBody = .HTMLBody & "<td valign='middle'><b><img src='" & img4 & "'>"
 .HTMLBody = .HTMLBody & "Ligne 2 - cols 2</b></td>"
 .HTMLBody = .HTMLBody & "<td valign='middle'><b>Ligne 2 - cols 3</b></td>"
 .HTMLBody = .HTMLBody & "</table></div>"
 .HTMLBody = .HTMLBody & "</body>"
 '.Display
 .Save
 .Send 'envoi automatique
 Loop Until (Range("A" & nbcontact) = "")
et ca marche..... uniquement sur Outlook.... mais pas sur Hotmail ou courrier ou gmail où les images ne s'affichent pas... et le input text lui uniquement sur Gmail...
que faire pour résoudre ces 2 problèmes ?
Merci.
look
j'ai bien l'impression que je vais devoir m'orienter vers CDO, mais là suis perdu.
N'y-aurait-il pas un tuto ?
je vois bien un truc du genre, faut mettre "" et non ' ou "/" et non '/' ou "\" ou '\'....
qu'en pensez vous ?
avec gmail, cela donne ca.... l'input text fonctionne..
et sur COURRIER, ca donne ca :
look gmail look courrier
Rechercher des sujets similaires à "afficher image htmlbody vba hors outlook"
