Accélération macro
j'ai écrit une macro qui fonctionne mais le seul problème c'est qu'elle est très lente à l'exécution.
Est ce que qqn pourrait m'aider à l'accélérer?
Sub Macro1()
' Macro1 Macro
Application.Calculation = xlCalculationManual
    Range("D5").Select
    Sheets("Activité CMO 2020").Select
    Range("Tableau1").Select
    Selection.ListObject.ListRows.Add (1)
    Sheets("Formulaire").Select
    Range("D5").Select
    Selection.Copy
    Range("A2").Select
        :=False, Transpose:=False
    Range("A2").Select
    Range("D7").Select
    Selection.Copy
    Range("B2").Select
    Range("D9").Select
    Selection.Copy
    Range("C2").Select
    Range("D11").Select
    Selection.Copy
    Range("D2").Select
    Range("D13").Select
    Selection.Copy
    Range("E2").Select
    Range("D15").Select
    Selection.Copy
    Range("F2").Select
    Range("D17").Select
    Selection.Copy
    Range("G2").Select
    ActiveSheet.Paste
    Range("D19").Select
    Selection.Copy
    Range("H2").Select
    ActiveSheet.Paste
    Range("A2:H2").Select
    Selection.Borders(xlDiagonalDown).LineStyle = xlNone
    Selection.Borders(xlDiagonalUp).LineStyle = xlNone
    Selection.Borders(xlEdgeLeft).LineStyle = xlNone
    Selection.Borders(xlEdgeTop).LineStyle = xlNone
    Selection.Borders(xlEdgeBottom).LineStyle = xlNone
    Selection.Borders(xlEdgeRight).LineStyle = xlNone
    Selection.Borders(xlInsideVertical).LineStyle = xlNone
    Selection.Borders(xlInsideHorizontal).LineStyle = xlNone
    Range("D5").Select
    Selection.ClearContents
    Range("D7").Select
    Range("D9").Select
    Range("D11").Select
    Range("D13").Select
    Range("D15").Select
    Range("D17").Select
    Range("D19").Select
    Range("D5").Select
    Application.Calculation = xlCalculationAutomatic
bonjour,
Peut-être quque chose comme ça :
Sub Macro1()
With Sheets("Activité CMO 2020")
   .Range("A2") = Range("D5").Value
   .Range("B2") = Range("D7").Value
   .Range("C2") = SRange("D9").Value
   .Range("D2") = SRange("D11").Value
   .Range("E2") = Range("D13").Value
   .Range("F2") = Range("D15").Value
   .Range("G2") = SRange("D17").Value
   .Range("H2") = Range("D19").Value
Range("D5,D7,D9,D11,D13,D15,D17,D19").ClearContents
EDIT : Sinon joindre le fichier
lorsque je fais votre macro, Excel me dit que Sub Macro1() n'est pas définie
C'est la seule chose que je n'ai pas modifiée !
11formulaire.xlsm (28.08 Ko)
Voila le fichier. il faut savoir que la macro s'effectue rapidement ici mais que dans le fichier final il y a bcp de feuilles rattachées
N'oublier pas si cela n'est pas déjà fait d'utiliser la fonction Application.ScreenUpdating
Au tout début de votre code
Et à la fin de votre code
Cela pourrait vous faire gagner un peu de temps
ScreenUpdating et (CalculationManual) ne sert à rien quand c'est bien fait !
Je te conseille de modifier ton fichier comme le fichier ci joint.
Pour les besoins de la macro j'ai modifié dans le Gestionnaire de Nom le tableau structuré de la feuille Activité :
Il est désormais baptisé "TActiv"
Dans ta feuilles Liste je te conseille de séparer tes différentes Listes par une colonne vide (comme j'ai fait.)
Ensuite tu supprimeras tous les noms de ton Gestionnaire de noms relatifs aux 4 colonnes de cette feuille.
Puis tu créeras des tableaux structurés pour les Médecins, Traitements, Infirmières et Aides et tu les renommeras comme j'ai fait.
Ensuite tu te serviras de ces noms pour ta validation de donnée.
16formulaire-vg.xlsm (28.70 Ko)
Hello tout le monde,
Galopin01, pourquoi conseilles-tu de séparer les différentes listes par une colonne vide ?
J'avais tendance intuitivement à le faire aussi et puis, ne voyant pas ce que ça changeait dans les faits, j'ai arrêté.
Par avance merci pour ta réponse, et pour les années passées sur les différents forums à éclairer les gens comme moi !
MERCIII BEAUCOUP !!!
1 Ça permet de les trier sans avoir à se poser de question
2 Pour en faire des tableaux structurés c'est indispensable.
...Mais même si on fait pas de tableaux structurés et que ce sont des listes dynamiques, intuitivement et visuellement c'est quand même plus "parlant" !
Merci pour l'info Galopin01 ! (et désolé pour le temps de réponse, je suis passé à côté ...)
Je les crée bien avec une colonne d'espacement mais, des fois, les regroupe ensuite par blocs thématiques. Si au final ça ne change pas grand chose, c'est parfait !
Rechercher des sujets similaires à "acceleration macro"
