2 items en 1 Combobox
Svp, Je veux regrouper deux éléments de la colonne E en un item dans combobox ( CLS="CC"+"DD" )
Merci.
Dim WS As Worksheet
Dim Plage As Range, Cell As Range
Dim c As Byte, x As Integer, y As Integer
Set WS = ThisWorkbook.Worksheets("Feuil1")
Set Plage = WS.Range("A2:A" & WS.Range("A1000").End(xlUp).Row)
Me.ComboBox1 = "TOUT"
Me.ComboBox2 = "TOUT"
Me.ListBox1.ColumnCount = 7
For Each Cell In Plage
    If Cell.Offset(0, 6) = "" Then                        'Entrée Seule
        With Me.ListBox1
        .AddItem Cell
            For c = 1 To 7
            .Column(c, x) = Cell.Offset(0, c)
            Next c
        x = x + 1
Next Cell
Me.ComboBox1.List = Array("A", "B", "TOUT")
Me.ComboBox2.List = Array("CLS", "ACC", "TOUT") 'CLS="CC"+"DD"
Dim WS As Worksheet
If Me.ComboBox1.ListIndex = -1 Then Exit Sub
If Me.ComboBox2.ListIndex = -1 Then Exit Sub
Me.ListBox1.Clear
                If Me.ComboBox1.Value <> "TOUT" And Me.ComboBox2.Value <> "TOUT" Then
                     If Cell.Offset(0, 5) = ComboBox1.Value Then
                        If Cell.Offset(0, 4) = ComboBox2.Value Then
                            With Me.ListBox1
                            .AddItem Cell
                                For c = 1 To 7
                                Next c
                            x = x + 1
                ElseIf Me.ComboBox1.Value <> "TOUT" And Me.ComboBox2.Value = "TOUT" Then
                        With Me.ListBox1
                        .AddItem Cell
                            For c = 1 To 7
                            Next c
                        x = x + 1
                ElseIf Me.ComboBox1.Value = "TOUT" And Me.ComboBox2.Value <> "TOUT" Then
                        With Me.ListBox1
                        .AddItem Cell
                            For c = 1 To 7
                            Next c
                        x = x + 1
                ElseIf Me.ComboBox1.Value = "TOUT" And Me.ComboBox2.Value = "TOUT" Then
                    With Me.ListBox1
                    .AddItem Cell
                        For c = 1 To 7
                        Next c
                    x = x + 1
Next Cell
sans titre
13v01.xlsm (26.84 Ko)
Bonjour Anass1 le forum
ton fichier en retour, avec ce que tu veux
a+
Papou
19anass1-v1.xlsm (33.86 Ko)
Bonjour paritec, le forum
Magnifique
Merci bcp pour votre aide.
Rechercher des sujets similaires à "items combobox"
