VBA Excel --> MsProject
c
Bonjour a tous,
Pour ceux qui cherche des bout de codes pour piloter MsProject à partir d'Excel, ayant beaucoup galéré.
La macro recupere les données sur la feuille "Ro_Upgrade"
Option Explicit 'U_Project
Option Private Module
Dim pjApp As MSProject.Application
Dim I As Integer, P As Integer
Sub NewProject()
' Ouverture Ms project
Set pjApp = New MSProject.Application
pjApp.FileNew
' Création des tâches
P = 1
For I = 105 To 119
pjApp.ActiveProject.Tasks.Add (Worksheets("Ro_Upgrade").Cells(I, 5).Value)
pjApp.ActiveProject.Tasks(P).Duration = (Worksheets("Ro_Upgrade").Cells(I, 8).Value) * 60
pjApp.ActiveProject.Tasks(P).Text1 = (Worksheets("Ro_Upgrade").Cells(I, 4).Value)
pjApp.ActiveProject.Tasks(P).Text2 = (Worksheets("Ro_Upgrade").Cells(I, 8).Value)
pjApp.ActiveProject.Tasks(P).Estimated = False
pjApp.ActiveProject.Tasks(P).Manual = False
' Liaisons des tâches
If I = 106 Then
pjApp.ActiveProject.Tasks(P).Predecessors = "1DD"
If I = 107 Then
pjApp.ActiveProject.Tasks(P).Predecessors = 2
If I = 108 Then
If I >= 109 And I <= 117 Then
pjApp.ActiveProject.Tasks(P).Predecessors = "4;3;2"
If I = 116 Then ' Embal./ Manut./ Transp.
pjApp.ActiveProject.Tasks(P).Predecessors = "11;5;6;7;8;9;10"
If I = 117 Then
pjApp.ActiveProject.Tasks(P).Predecessors = "10FF;5FF;7FF;8FF;9FF"
If I = 118 Then
pjApp.ActiveProject.Tasks(P).Predecessors = 12
If I = 119 Then
pjApp.ActiveProject.Tasks(P).Predecessors = 14
P = P + 1
Next I
' Démarrage manuel du projet
pjApp.ActiveProject.Tasks(1).Manual = True
' Date de démarrage
pjApp.ActiveProject.Tasks(1).Start = "19/09/2022"
' ############a travailler ###########
' Les couleurs de Gantt
' 3506515 MiddleColor:=238746 EndColor:=&H538135
pjApp.GanttBarFormatEx TaskID:=1, StartColor:=238746, MiddleColor:=238746, EndColor:=238746
pjApp.GanttBarFormatEx TaskID:=2, StartColor:=5383172, MiddleColor:=5383172, EndColor:=5383172
pjApp.GanttBarFormatEx TaskID:=3, StartColor:=5383172, MiddleColor:=5383172, EndColor:=5383172
pjApp.GanttBarFormatEx TaskID:=4, StartColor:=192, MiddleColor:=192, EndColor:=192
pjApp.GanttBarFormatEx TaskID:=12, StartColor:=16750899, MiddleColor:=16750899, EndColor:=16750899
pjApp.GanttBarFormatEx TaskID:=13, StartColor:=3381759, MiddleColor:=3381759, EndColor:=3381759
pjApp.GanttBarFormatEx TaskID:=14, StartColor:=23381606, MiddleColor:=3381606, EndColor:=3381606
pjApp.GanttBarFormatEx TaskID:=15, StartColor:=26112, MiddleColor:=26112, EndColor:=26112
''''''pjApp.Visible = True
' Création et affichage des colonnes
pjApp.TableEditEx Name:="&Entrée", TaskTable:=True, NewFieldName:="Text1", _
Width:=12, AlignTitle:=pjCenter, ShowInMenu:=True, ShowAddNewColumn:=1, Align:=1, AlignTitle:=1, ColumnPosition:=-1
pjApp.TableApply Name:="&Entrée"
pjApp.TableEditEx Name:="&Entrée", TaskTable:=True, NewFieldName:="Text2", _
pjApp.TableEditEx Name:="&Entrée", TaskTable:=True, NewFieldName:="Text3", _
Width:=6, AlignTitle:=pjCenter, ShowInMenu:=True, ShowAddNewColumn:=1, Align:=1, AlignTitle:=1, ColumnPosition:=-1
pjApp.TableApply "&Entrée"
pjApp.TableEditEx Name:="&Entrée", TaskTable:=True, NewFieldName:="Text4", _
pjApp.TableEditEx Name:="&Entrée", TaskTable:=True, NewFieldName:="Text5", _
Width:=10, AlignTitle:=pjCenter, ShowInMenu:=True, ShowAddNewColumn:=1, Align:=1, AlignTitle:=1, ColumnPosition:=-1
pjApp.TableEditEx Name:="&Entrée", TaskTable:=True, NewFieldName:="Text6", _
pjApp.TableEditEx Name:="&Entrée", TaskTable:=True, NewFieldName:="Text7", _
Width:=50, AlignTitle:=pjCenter, ShowInMenu:=True, ShowAddNewColumn:=1, Align:=1, AlignTitle:=1, ColumnPosition:=-1
' Rajout des noms sans modifier la struture
pjApp.SelectTaskColumn Column:="Text1"
pjApp.CustomFieldRename FieldID:=pjCustomTaskText1, NewName:="Imputation"
pjApp.SelectTaskColumn Column:="Text2"
pjApp.CustomFieldRename FieldID:=pjCustomTaskText2, NewName:="Heures RO"
pjApp.SelectTaskColumn Column:="Text3"
pjApp.CustomFieldRename FieldID:=pjCustomTaskText3, NewName:="RO"
pjApp.SelectTaskColumn Column:="Text4"
pjApp.CustomFieldRename FieldID:=pjCustomTaskText4, NewName:="Ordre SAP"
pjApp.SelectTaskColumn Column:="Text5"
pjApp.CustomFieldRename FieldID:=pjCustomTaskText5, NewName:="Chef de projet"
pjApp.SelectTaskColumn Column:="Text6"
pjApp.CustomFieldRename FieldID:=pjCustomTaskText6, NewName:="CDE Client"
pjApp.SelectTaskColumn Column:="Text7"
pjApp.CustomFieldRename FieldID:=pjCustomTaskText7, NewName:="Suivi"
' Les couleurs des colonnes
pjApp.Font32Ex CellColor:=15189684
pjApp.Font32Ex CellColor:=10092543
' Supresion affichage
pjApp.SelectTaskColumn Column:="Prédécesseurs"
pjApp.ColumnDelete
pjApp.SelectTaskColumn Column:="Noms ressources"
pjApp.ColumnDelete
pjApp.ColumnDelete
pjApp.ColumnDelete
pjApp.ColumnDelete
pjApp.ColumnDelete
pjApp.ColumnDelete
' Enregistrement du planning
pjApp.FileSaveAs ThisWorkbook.Path & "\" & Sheets("Ro_Upgrade").Range("M5") & "_" & Sheets("Ro_Upgrade").Range("G5") & "_" & Sheets("Ro_Upgrade").Range("G7") & "_" & "Planning.mpp"
' -- Document: fermer,quitter,libérer la mémoire et j'en passe :-)
'pjApp.FileClose: pjApp.Quit
Set pjApp = Nothing: Set pjApp = Nothing
End SubNote :les "ColumnDelete" --> Un projet général avec les ressources reprend ces sous projets et permet de garder la structure par défaut de Ms Projet.
Reste à travailler les dates ( a partir de demain)
En espérant que cela puis aider
Bien cordialement
Alain
