Interdire le copier - coller
s
souri84Membre impliqué
- Messages
- 1'036
- Excel
- 2003 FR / 2007 UK
- Inscrit
- 07/05/2007
- Emploi
- Consultant en finance
Je fournis ici le code trouvé sur un autre forum il y a environ 6 mois pour empêcher le copier coller...
En effet, beaucoup de posts concernent le fait d'interdire cette manip.
Sub InterdireCopierCouper()
On Error Resume Next
With Application
'disables shortcut keys
.OnKey "^c", ""
.OnKey "^v", ""
.OnKey "^x", ""
'Disables Copy
.CommandBars("Edit").FindControl(ID:=19).Enabled = False
.CommandBars("Edit").FindControl(ID:=848).Enabled = False
.CommandBars("Cell").FindControl(ID:=19).Enabled = False
.CommandBars("Column").FindControl(ID:=19).Enabled = False
.CommandBars("Row").FindControl(ID:=19).Enabled = False
.CommandBars("Button").FindControl(ID:=19).Enabled = False
.CommandBars("Formula Bar").FindControl(ID:=19).Enabled = False
.CommandBars("Worksheet Menu Bar").FindControl(ID:=19).Enabled = False
.CommandBars("Standard").FindControl(ID:=19).Enabled = False
.CommandBars("Button").FindControl(ID:=848).Enabled = False
.CommandBars("Formula Bar").FindControl(ID:=848).Enabled = False
.CommandBars("Worksheet Menu Bar").FindControl(ID:=848).Enabled = False
.CommandBars("Standard").FindControl(ID:=848).Enabled = False
.CommandBars("Ply").FindControl(ID:=848).Enabled = False
'Disables Cut
.CommandBars("Edit").FindControl(ID:=21).Enabled = False
.CommandBars("Cell").FindControl(ID:=21).Enabled = False
.CommandBars("Column").FindControl(ID:=21).Enabled = False
.CommandBars("Row").FindControl(ID:=21).Enabled = False
.CommandBars("Button").FindControl(ID:=21).Enabled = False
.CommandBars("Formula Bar").FindControl(ID:=21).Enabled = False
.CommandBars("Worksheet Menu Bar").FindControl(ID:=21).Enabled = False
.CommandBars("Standard").FindControl(ID:=21).Enabled = False
'Disable Paste
.CommandBars("Edit").FindControl(ID:=22).Enabled = False
.CommandBars("Cell").FindControl(ID:=22).Enabled = False
.CommandBars("Column").FindControl(ID:=22).Enabled = False
.CommandBars("Row").FindControl(ID:=22).Enabled = False
.CommandBars("Button").FindControl(ID:=22).Enabled = False
.CommandBars("Formula Bar").FindControl(ID:=22).Enabled = False
.CommandBars("Worksheet Menu Bar").FindControl(ID:=22).Enabled = False
.CommandBars("Standard").FindControl(ID:=22).Enabled = False
'Disable PasteSpecial
.CommandBars("Edit").FindControl(ID:=755).Enabled = False
.CommandBars("Cell").FindControl(ID:=755).Enabled = False
.CommandBars("Column").FindControl(ID:=755).Enabled = False
.CommandBars("Row").FindControl(ID:=755).Enabled = False
.CommandBars("Button").FindControl(ID:=755).Enabled = False
.CommandBars("Formula Bar").FindControl(ID:=755).Enabled = False
.CommandBars("Worksheet Menu Bar").FindControl(ID:=755).Enabled = False
.CommandBars("Standard").FindControl(ID:=755).Enabled = False
End SubCe code est à insérer dans un module.
Pour insérer un bouton rétablissant le copier coller, reprenez le même code mais remplacez les "false" par des "true"
t
ça marche super bien, tellement bien que ça interdit même mes autres fichiers excel.
Auriez-vous une astuce pour ça ne s'applique qu'à un seul fichier?
