Slt medmed,
à tester
Sub transformerenColonne_new()
Dim x As Worksheet, y As Worksheet
Dim i As Integer, lastrow_x As Integer, lastrow_y As Integer, lastcol_x As Integer
Dim z As Range
Set x = ThisWorkbook.Sheets(1)
Set y = ThisWorkbook.Sheets(2)
Set z = x.UsedRange
FillRange = VBA.Array("sexe", "poste", "voiture")
y.Range("D1:F1").Value = FillRange
lastrow_x = z.Rows.Count
lastcol_x = z.Columns.Count
lastrow_y = y.Range("A1").Rows.Count + 1
For i = 1 To lastrow_x - 1
If x.Cells(i, 1).Value <> 0 Then
y.Range(y.Cells(lastrow_y, 1), y.Cells(lastrow_y + 3, 1)).Value = Application.Transpose(x.Range(x.Cells(1, 1), x.Cells(1, 4)).Value)
y.Range(y.Cells(lastrow_y, 2), y.Cells(lastrow_y + 3, 2)).Value = Application.Transpose(x.Range(x.Cells(i + 1, 1), x.Cells(i + 1, 4)).Value)
y.Range(y.Cells(lastrow_y + 3, 3), y.Cells(lastrow_y + 3, 6)).Value = x.Range(x.Cells(i + 1, 5), x.Cells(i + 1, 8)).Value
lastrow_y = lastrow_y + 4
y.Columns("A:F").Cells.HorizontalAlignment = xlCenter
ou comme ca, comme tu veux
Sub transformerenColonne_new1()
Dim z As Range
Set z = x.UsedRange
y.Cells(lastrow_y, 1).Value = x.Cells(1, 1).Value
y.Cells(lastrow_y + 1, 1).Value = x.Cells(1, 2).Value
y.Cells(lastrow_y + 2, 1).Value = x.Cells(1, 3).Value
y.Cells(lastrow_y + 3, 1).Value = x.Cells(1, 4).Value
y.Cells(lastrow_y, 2).Value = x.Cells(i + 1, 1).Value
y.Cells(lastrow_y + 1, 2).Value = x.Cells(i + 1, 2).Value
y.Cells(lastrow_y + 2, 2).Value = x.Cells(i + 1, 3).Value
y.Cells(lastrow_y + 3, 2).Value = x.Cells(i + 1, 4).Value
y.Cells(lastrow_y + 3, 3).Value = x.Cells(i + 1, 5).Value
y.Cells(lastrow_y + 3, 4).Value = x.Cells(i + 1, 6).Value
y.Cells(lastrow_y + 3, 5).Value = x.Cells(i + 1, 7).Value
y.Cells(lastrow_y + 3, 6).Value = x.Cells(i + 1, 8).Value
