Programmer une tache
Bonjour qui peut m aider a modifier ce code cordialement
Private Function vbScheduleJob(strCommand As String, sjTime As Date, _
    AddFlags As JobAdd, Optional DayOfWeek As sjWeekdays = 0, _
    Optional DayOfMonth As sjDays = 0, Optional PCName As String = vbNullString) As Long
    Dim myInfo As AT_INFO
    Dim JobID As Long
    With myInfo
        .Command = StrConv(strCommand, vbUnicode)
        .Flags = AddFlags
        .JobTime = DateDiff("s", "00:00:00", Format(sjTime, "hh:mm:ss")) * 1000
        .DaysOfWeek = DayOfWeek
        .DaysOfMonth = DayOfMonth
    NetScheduleJobAdd PCName, myInfo, JobID
    vbScheduleJob = JobID
End Function
'Source:
'http://www.tek-tips.com/viewthread.cfm?qid=794484
Private Declare Function NetScheduleJobAdd Lib "netapi32.dll" _
(ByVal Servername As String, Buffer As Any, JobID As Long) As Long
Private Type AT_INFO
JobTime As Long
DaysOfMonth As Long
DaysOfWeek As Byte
Flags As Byte
Command As String
End Type
Private Enum JobAdd
JOB_RUN_PERIODICALLY = 1&
JOB_ADD_CURRENT_DATE = 8&
JOB_NONINTERACTIVE = 16&
End Enum
Private Enum sjWeekdays
Monday = 1
Tuesday = 2
Wednesday = 4
Thursday = 8
Friday = 16
Saturday = 32
Sunday = 64
End Enum
Private Enum sjDays
d1 = 1
d2 = 2
d3 = 4
d4 = 8
d5 = 16
d6 = 32
d7 = 64
d8 = 128
d9 = 256
d10 = 512
d11 = 1024
d12 = 2048
d13 = 4096
d14 = 8192
d15 = 16384
d16 = 32768
d17 = 65536
d18 = 131072
d19 = 262144
d20 = 524288
d21 = 1048576
d22 = 2097152
d23 = 4194304
d24 = 8388608
d25 = 16777216
d26 = 33554432
d27 = 67108864
d28 = 134217728
d29 = 268435456
d30 = 536870912
d31 = 1073741824
End Enum
Sub Test()
'(ouverture du bloc notes)
vbScheduleJob "notepad.exe", DateAdd("n", 1, Now), JOB_RUN_PERIODICALLY, Wednesday, d4
Tu n'obtiendra aucune réponse en t'y prenant de cette façon.
Explique nous plutôt qu'elle est le but du code, qu'est ce qui bloque, dans quelle mesure tu souhaites adapter ce code, as-tu un fichier exemple ?
Nous ne sommes pas devin
A plus !
Bonjour j ai une macro a executer a chaque ouverture d excel tous les jours. Donc je cherche une solution pour ouvrir et fermer excel. Sans le faire manuellement c pour verifier les dates et etre avertit par mail.
(Puis l execution de macro en fonction de la date du jour et de la colonne A date) = condition
La solution la plus simple est d'utiliser l'option d'exécution de fichier au démarrage d'Excel:
Options Avancées --> Général --> Au démarrage, ouvrir ......
Cela consiste en quoi, ouvrir le fichier au demerrage de l ordinateur par exemple, ou encore ouvre excel tous les jours a 9h par exmple et ferme excel. Je ne connais pas
Comme décrit dans les options de l'application Excel (Options Avancées --> Général ), vous pouvez spécifier un dossier qui contiendra les fichiers à ouvrir dès le lancement de l'application. Il suffit alors d'y placer votre fichier avec votre macro et cette dernière sera systématiquement exécutée dès l'ouverture d'Excel.
Non c pas ca, je cherche a ouvrir et fermer excel de facon automatiquement sans que j ai a ouvrir excel tout les jours genre a 9h. Si je suis pas au bureau par exemple l ordi est allume et envoi l email de façon automatique
Je ne vois pas bien l'intérêt d'utiliser cette fonction.
Vous pouvez programmer de façon très précise : jours et heure, l'exécution de votre macro via le planificateur de tâches.
C la que je sais pas faire ni comment
Bouton démarrer --> Outils d’administration --> planificateur de tâches --> menu action --> créer une tâche
1- général : cocher exécuter avec les autorisations maximales
2- déclencheur : nouveau --> paramètres : cocher chaque semaine et positionner vos paramètres
3- Actions : nouveau --> spécifier le fichier à exécuter
4- Conditions et Paramètres : options par défaut
Merci juque la je comprend mais je mais quoi un fichier.vbs ou excel lien microsoft plus fichier plus lien car en mettant excel j ai tentative reussit mais mon fichier excel n est pas rester ouvert comme demander il y a une tape que je reussit pas
Désolé je passe la main car j'ai du mal à déchiffrer votre expression écrite.
Ouvrir un fichier excel c ma demande. C simple .
A des demandes formulées en langage SMS, je n'y réponds que sur mon smartphone.
Ben je suis avec mon téléphone
Je récapitule la tâche du planificateur ca je sais faire.
Mais je n y arrive pas.
Avec un fichier vos ou en direct avec lien Excel
Donc je ne sais pas faire
Bonjour planificateur de taches ok le fichier s ouvre
"C:\Program Files (x86)\Microsoft Office\Office12\EXCEL.EXE"
arguments = le nom du fichier
commencer = lien du fichier
content ca ouvre le fichier
ma macro envoi mon mail
d 'après vous ou dois je mettre la fermeture du fichier soit forcer l'arret apres l 'execution de la macro
A mettre à la fin de ton code :
ActiveWorkbook.Close
merci beaucoup donc a la fin de macro mais pouvez vous me dire comment faire une condition en vba
If TaCondition then
'Si vrai
'Si faux
End if
Rechercher des sujets similaires à "programmer tache"
