Simplification de code
Bonjour à vous, je cherche à simplifier ce code qui mets plus de 6 minutes à se réaliser. Merci d'avance
Sub Novembre_Rectangleàcoinsarrondis3_Cliquer()
Sheets("INDEX").Select
    Columns("H:M").Select
    Selection.Copy
    Sheets("Prime Novembre").Select
    Columns("A:A").Select
    Selection.PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
        False, Transpose:=False
'NOELLOU 1
    Sheets("Novembre").Select
    Range("AQ5:BT5").Select
    Selection.Copy
    Range("C2").Select
        :=False, Transpose:=True
    ActiveWorkbook.Worksheets("Prime Novembre").Sort.SortFields.Clear
    ActiveWorkbook.Worksheets("Prime Novembre").Sort.SortFields.Add Key:=Range( _
        "C2"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
    With ActiveWorkbook.Worksheets("Prime Novembre").Sort
        .SetRange Range("C2:C41")
        .Header = xlGuess
        .MatchCase = False
        .Orientation = xlTopToBottom
        .SortMethod = xlPinYin
        .Apply
    'LAFONT 2
    Range("AQ6:BT6").Select
    Selection.Copy
    Range("C42").Select
        "C42"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C42:C81")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'DOUAY 3
    Range("AQ7:BT7").Select
    Selection.Copy
    ActiveWindow.SmallScroll Down:=26
    Range("C82").Select
        "C82"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C82:C121")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'IRISSOU 4
    Range("AQ8:BT8").Select
    Selection.Copy
    ActiveWindow.SmallScroll Down:=18
    Range("C122").Select
        "C122"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C122:C161")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'DRIE 5
    Range("AQ9:BT9").Select
    Selection.Copy
    ActiveWindow.SmallScroll Down:=20
    Range("C162").Select
        "C162"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C162:C201")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'GUILLEMET 6
    Range("AQ10:BT10").Select
    Selection.Copy
    Range("C202").Select
        "C202"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C202:C241")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'SALA 7
    Range("AQ11:BT11").Select
    Selection.Copy
    Range("C242").Select
        "C242"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C242:C281")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'LHUILLERY 8
    Range("AQ12:BT12").Select
    Selection.Copy
    Range("C282").Select
        "C282"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C282:C321")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'CARNEVILLIER 9
    Range("AQ13:BT13").Select
    Selection.Copy
    Range("C322").Select
        "C322"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C322:C361")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'MADI 10
    Range("AQ14:BT14").Select
    Selection.Copy
    Range("C362").Select
        "C362"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C362:C401")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'ARAUX 11
    Range("AQ15:BT15").Select
    Selection.Copy
    Range("C402").Select
        "C402"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C402:C441")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'CHARGUI 12
    Range("AQ16:BT16").Select
    Selection.Copy
    Range("C442").Select
        "C442"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C442:C481")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'TASSIN 13
    Range("AQ17:BT17").Select
    Selection.Copy
    Range("C482").Select
        "C482"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C482:C521")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'TOPA 14
    Range("AQ18:BT18").Select
    Selection.Copy
    Range("C522").Select
        "C522"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C522:C561")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'MOLIA 15
    Range("AQ19:BT19").Select
    Selection.Copy
    Range("C562").Select
        "C562"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C562:C601")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'PERDEREAU 16
    Range("AQ20:BT20").Select
    Selection.Copy
    Range("C602").Select
        "C602"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C602:C641")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'VINCENT 17
    Range("AQ21:BT21").Select
    Selection.Copy
    Range("C642").Select
        "C642"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C642:C681")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'LE BERDER 18
    Range("AQ22:BT22").Select
    Selection.Copy
    Range("C682").Select
        "C682"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C682:C721")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'DELOR 19
    Range("AQ23:BT23").Select
    Selection.Copy
    Range("C722").Select
        "C722"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C722:C761")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    'SMAGGHE 20
    Range("AQ24:BT24").Select
    Selection.Copy
    Range("C762").Select
        "C762"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
        xlSortNormal
        .SetRange Range("C762:C801")
        .Header = xlGuess
        .MatchCase = False
        .Apply
    ThisWorkbook.Worksheets("Prime Novembre").Activate
j = 1
For i = 1 To Range("C2000").End(xlUp).Row 'calcule la dernière cellule remplie dans la colonne 3 colonne C
If Cells(j, 3).Value = FAUX Then
Cells(j, 3).EntireRow.Delete
j = j + 1
Range("c1:c800").Select
For Each cell In Selection
If cell.Value = "1" Then
cell.Interior.ColorIndex = 16
If cell.Value = "7" Then
If cell.Value = "8" Then
If cell.Value = "14" Then
If cell.Value = "15" Then
If cell.Value = "21" Then
If cell.Value = "22" Then
If cell.Value = "28" Then
If cell.Value = "29" Then
Range("e1:e800").Select
If cell.Value = "2" Then
If cell.Value = "9" Then
If cell.Value = "16" Then
If cell.Value = "23" Then
If cell.Value = "30" Then
Range("C:C,E:E").Select
    Selection.NumberFormat = "dd"
    Application.Goto Range("A1"), True
https://www.cjoint.com/c/EJDlmUk7uKG
faire la maintenance (faire évoluer) d'un code suppose que celui-ci soit commenté, et si possible documenté)
c'est d'autant plus crucial que le code est long
sinon on risque le pire
je viens d'ajouter le fichier mais il ne s'affiche pas
le fichier est trop gros
J'ai fait un essai, mais sans fichier pas évident de savoir si cela fonctionne
Dim Ligne As Long, LgRecopie As Long, Cell As Range
  With Sheets("Prime Novembre")
    Sheets("INDEX").Columns("H:M").Copy .Columns("A:A")
    LgRecopie = 2
    For Ligne = 5 To 24
      Sheets("Novembre").Range("AQ" & Ligne & ":BT" & Ligne).Copy
      .Range("C" & LgRecopie).PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=True
      .Range("C" & LgRecopie).Resize(40).Sort key1:=.Range("C" & LgRecopie), order1:=xlAscending, dataoption1:=xlSortNormal, Header:=xlGuess
      LgRecopie = legrecopie + 40
    Next Ligne
    For Ligne = .Range("C2000").End(xlUp).Row To 1 Step -1  'calcule la dernière cellule remplie dans la colonne 3 colonne C
      If Cells(Ligne, "C").Value = FAUX Then
        .Rows(Ligne).Delete
    Next Ligne
    For Each Cell In .Range("c1:c800")
      Select Case Cell.Value
      Case "1", "7", "8", "14", "15", "21", "22", "28", "29": Cell.Interior.ColorIndex = 16
      End Select
    Next Cell
    For Each Cell In .Range("E1:E800")
      Case "1", "2", "8", "9", "15", "16", "22", "23", "29", "30": Cell.Interior.ColorIndex = 16
      End Select
    Next Cell
    .Range("C:C,E:E").NumberFormat = "dd"
    Application.Goto .Range("A1"), True
essayes avec cjoint
Tu peux préciser un peu plus
Dans ton code tu copies de la page "Novembre" AQ5:BT5, cela ne serait pas AU5:BX5 ?
Ensuite tu copie dans la page "Prime Novembre" en C2 ?????????????
Je suis perplexe
oui tu as raison banzai , j'ai inseré des colonne se qui à décaler le tableau
je recuperer les valeur G de chaque ligne ce qui me donne les permanences montées de chaques personnes et je les transposes en C2,
c'est la seul idées qui m'est venue pour retranscrire mon planning en liste de permanence montée
Je comprends pas pourquoi tu copies en C2 dans la page "Prime Novembre", dedans il y a un numéro de jour
Non il n'y en a pas, ce sont les valeurs de AU5:BX5 qui se transposent dans la colonne C
Je suis toujours dubitatif quand à la destination des données
prime novembre
Tu devrais fournir un fichier avec la page "Prime Novembre" remplie et les pages "Index" et "Novembre"
si tu regardes la macro tu verras qu' a la fin j' ai demandé que les colonnes C et D soitent en format "dd" et sur ma feuille "Prime Novembre" je demande à ce que la valeur de E soit égal à C + 1. J'ai fais cela pour que si C=31 E=01.
voilà ce que je demande dans ma macro :
1. Copier la mise en forme de INDEX sur ma feuille Prime Novembre
2. Récupérer les valeurs comprisent entre AU et BX de chaques lignes de mon tableau novembre et les transposer en colonne C de ma feuille Prime Novembre
3. Supprimer les doublons
4. Colorier les cases dont les valeurs sont ...
5. Mettre les colonnes C et E au format "dd".
Merci Banzai64 pour ton travail,impressionnant, ce qui prenait 6 minutes avant ne prend plus que 5 Secondes. Pourrais tu m'expliquer un peu le code parce que là je nage complet lol
Bonsoir
Très simple
Une boucle de 5 à 24 qui copie les valeurs de AU à BX en les les transposant dans la colonne C par pas de 40
On tri chaque bloc de 40 données (attention Header:=xlNo)
Suppression des lignes avec FAUX et les lignes vides par un filtre (c'est plus rapide que de faire ligne par ligne)
Coloriage des dates voulues
C'est fini
Pour info : Je pense (à 90%) que l'on pourrait utiliser la même macro (en l'adaptant bien sur) pour toutes les pages
Je viens de retranscrire ton code sur les différents mois. Un grand merci à toi pour ton aide et ta patience.
Rechercher des sujets similaires à "simplification code"
