Salut Moka,
essaie avec cette fonction:
Function compteCoulMFC(champ As Range, coul)
Application.Volatile
For Each c In champ
If CouleurMFC(c) = coul Then
t = t + 1
Next c
compteCoulMFC = t
End Function
Function CouleurMFC(cel)
Set c = Range(cel.Address)
ff = Array("Somme", "aujourdhui()", "nb.si", "equiv", "recherchev", _
"Nbval", "sommeprod", "joursem", "gauche", "droite", "stxt")
fa = Array("Sum", "today()", "countif", "match", "vlookup", _
"counta", "sumproduct", "weekday", "left", "right", "mid")
a = Array("=", ">", "<", ">=", "<=", "<>", "BETWEEN")
b = Array(xlEqual, xlGreater, xlLess, xlGreaterEqual, xlLessEqual, xlNotEqual, xlBetween)
i = 1
Do While i <= c.FormatConditions.Count And Not témoin
If c.FormatConditions(i).Type = xlCellValue Then
tmp1 = Evaluate(c.FormatConditions(i).Formula1)
oper = a(Application.Match(c.FormatConditions(i).Operator, b, 0) - 1)
If oper <> "BETWEEN" Then
If Evaluate(c & oper & tmp1) Then
coul = c.FormatConditions(i).Interior.ColorIndex
témoin = True
tmp2 = Evaluate(c.FormatConditions(i).Formula2)
If Evaluate("AND(" & c & ">=" & tmp1 & "," & c & "<=" & tmp2 & ")") Then
témoin = True
Z = c.FormatConditions(i).Formula1
For k = LBound(ff) To UBound(ff)
Z = Replace(Z, UCase(ff(k)), UCase(fa(k)))
Next k
If Evaluate(Z) = True Then
témoin = True
i = i + 1
Loop
CouleurMFC = coul
End Function
