Link data from multiple worksheets which uses the same cells values
I have a problem.
I want to extract data to create a list from workbook (B) into another workbook (A).
NB: Using the "=" sign is hard and long to extract data.
So my point is:
On workbook (A), I have a list of countries names from row A2 to row A51
Next. On workbook (B). Each country has it own "worksheet". From worksheet #1 to Worksheet #50 and all the values are in cells "F2 & G2" respectively.
I want excel to grab each worksheet values in "F2 & G2" in workbook (B) and paste it as a list in workbook (A) in worksheet (1).
How can I do that?
Hello (you may start a message with something like that...),
A possibility :
Sub ImportData()
Dim Rw As Long, RwMax As Long, WbSource As Workbook, Country As String
On Error Resume Next
Set WbSource = Workbooks.Open(Filename:="C:\User\FullPath\WorkbookBname.xlsx") 'Filename to adapt
With ThisWorkbook.Sheets(1)
    RwMax = .Range("A" & Rows.Count).End(xlUp).Row 'Last row
    For Rw = 1 To RwMax 'loop on rows
        Country = .Range("A" & Rw)
        .Range("B" & Rw) = WbSource.Sheets(Country).Range("F2")
        .Range("C" & Rw) = WbSource.Sheets(Country).Range("G2")
WbSource.Close False
MsgBox "Work done !"
Each Worksheet in Workbook B have to be named like the searched country in column 1 Workbook A.
Hello. I sorry for my manners. Thanks for your reply.
I did change the file name, "(Filename:="C:\User\FullPath\WorkbookBname.xlsx")" to
(Filename:="C:\Users\Corey\Desktop\Anton Heatwave\PMI").
and I made and error to state where I want to paste the values.
To:
.Range("C" & Rw) = WbSource.Sheets(Country).Range("F2")
.Range("D" & Rw) = WbSource.Sheets(Country).Range("G2")
But somehow, it don't seems to work.
How can I get around this?
Thanks in advance
Filename may include full path (like C:\Users\Corey\Desktop\Anton Heatwave\PMI\) and workbook name (like WorkbookB.xlsx).
You can just test this code to be sure that the workbook is correctly opened :
Sub Test1()
    Workbooks.Open(Filename:="C:\User\FullPath\WorkbookName.xlsx") 'Filename to adapt
The test code don't seems to work.
Error states: Compile error: Syntax error.
Paste here the code you tested, please.
I'm not a soothsayer !
Sub Test1()
Workbooks.Open(Filename:="C:\Users\Corey\Desktop\Anton Heatwave\PMI") 'Filename to adapt
The above code
You are just reading half part of my responses...
Your actual filename is not valid.
Ohhh. I'm sorry going to try
This is the file name:
Sub Test1()
Workbooks.Open(Filename:="C:\Users\Corey\Desktop\Anton Heatwave\PMI") 'Countries Indicators #1 NSB (1)
Sub Test1()
This is still not a valid filename...
The right syntax is simple : Complete Path + \ + Workbook name + Extension
I gave you an example : C:\User\FullPath\WorkbookName.xlsx
Your filename doesn't look like to this one !
I don't know. That's the name of the excel file: Countries Indicators #1 NSB (1)
Sub Test1()
Workbooks.Open(Filename:="C:\Users\Corey\Desktop\Anton Heatwave\PMI") 'Countries Indicators #1 NSB (1).xlsx
I am only getting and error.
Sub Test1()
Workbooks.Open (Filename: = "C:\Users\Corey\Desktop\Anton Heatwave\PMI\Countries Indicators #1 NSB(1).xlsx") 'Filename to adapt
Still nothing
Sub Test1()
Still nothing
Hello,
That one look like a valid full name. If that's not working anymore, I can't help you.
Rechercher des sujets similaires à "link data multiple worksheets uses same values"
