Sub Turf()
Dim f As Worksheet
Dim ScriptControl As Object, PMU As Object, prog As Object, reu As Object, r As Object, hippo As Object
Dim Site As String, i As Long
suppfeuilles
Range("A1").CurrentRegion.Offset(2, 0).ClearContents
Set ScriptControl = CreateObject("MSScriptControl.ScriptControl")
ScriptControl.Language = "JScript"
Site = Range("C1").Value
With CreateObject("MSXML2.XMLHTTP")
.Open "GET", Site, False
.send
Set PMU = ScriptControl.Eval("(" + .responseText + ")")
.abort
i = 3
Set prog = PMU.programme
Set reu = prog.reunions
'On Error Resume Next
For Each r In reu
With ActiveSheet
.Cells(i, 1).Value = "R" & r.numOfficiel
Set hippo = r.hippodrome
.Cells(i, 2).Value = hippo.libelleCourt
i = i + 1
Next r
Set PMU = Nothing
Set ScriptControl = Nothing
Sub Turf2()
Dim ScriptControl As Object, PMU As Object, cou As Object, c As Object
suppfeuilles
Range("A1").CurrentRegion.Offset(2, 2).ClearContents
If Not Cells(Selection.Row, 1) Like "R*" Then
MsgBox "Sélectionner eune réunion !"
Exit Sub
Site = Range("C1").Value & Cells(Selection.Row, 1) & "/"
.send
.abort
i = Selection.Row
ActiveSheet.Cells(Selection.Row, 3) = ">>>"
Set cou = PMU.courses
For Each c In cou
With ActiveSheet
.Cells(i, 4).Value = .Cells(Selection.Row, 1) & "/C" & c.numOrdre
.Cells(i, 5).Value = c.libelle
i = i + 1
Next c
Set PMU = Nothing
Turf3
Sub Turf3()
Dim f As Worksheet, newf As Worksheet
Dim Ecurie As Object, Cheval As Object, Drd As Object, Gp As Object
Dim Site As String, li As Long
Set f = ActiveSheet
reunion = f.Range("B" & Selection.Row)
For i = Selection.Row To f.Range("D" & Rows.Count).End(xlUp).Row
RC = f.Range("D" & i)
Set newf = Sheets.Add(After:=Sheets(Sheets.Count))
newf.Name = Replace(RC, "/", " ")
Site = f.Range("C1").Value & RC & "/participants"
.send
.abort
li = 2
newf.Cells(1, 1) = f.Range("B1")
newf.Cells(1, 1).NumberFormat = "[$-F800]dddd, mmmm dd, yyyy"
newf.Cells(1, 2) = "Cheval"
newf.Cells(1, 3) = "Cote"
newf.Cells(1, 4) = reunion
newf.Cells(1, 5) = f.Range("E" & i)
Set Ecurie = PMU.participants
For Each Cheval In Ecurie
With ActiveSheet
newf.Cells(li, 1).Value = Cheval.numPmu
newf.Cells(li, 2).Value = Cheval.nom
Set Drd = Cheval.dernierRapportDirect
newf.Cells(li, 3).Value = Drd.rapport
li = li + 1
Next Cheval
newf.Cells.EntireColumn.AutoFit
Set PMU = Nothing
f.Select
Sub suppfeuilles()
Dim f As Worksheet
For Each f In Worksheets
If f.Name <> ActiveSheet.Name Then f.Delete
