PB fonction mathématique utilisant pi
Bonjour l'appelle de la fonction définie ci dessous donne l'erreur Type d'argument Byref incompatible pourquoi? Comment résoudre cela svp?
Le compilatuer bloque sur l'appelle de la fonction Nprime avec l'instruction Nprime(d1)
Merci d'avance.
Ludo
Function Nprime(z As Double) As Double
Nprime = (1 / (WorksheetFunction.Power(2 * WorksheetFunction.Pi, 0.5))) * Exp(-0.5 * WorksheetFunction.Power(z, 2))
End Function
Sub BSCALLPRICE()
Dim St, t, Ct, Ct2, Pt, K, K2, r, M, sigma, d1, d2, d12, d22, deltac, deltap, gammac, gammap, vegac, vegap, thetac, thetap, rhoc, rhop As Double
St = Worksheets("Feuil1").Cells(3, 1)
t = Worksheets("Feuil1").Cells(3, 6)
K = Worksheets("Feuil1").Cells(3, 2)
K2 = Worksheets("Feuil1").Cells(5, 2)
r = Worksheets("Feuil1").Cells(3, 4)
M = Worksheets("Feuil1").Cells(3, 5)
sigma = Worksheets("Feuil1").Cells(3, 3)
d1 = (WorksheetFunction.Ln(St / K) + (r + 0.5 * WorksheetFunction.Power(sigma, 2)) * (M - t)) / (sigma * WorksheetFunction.Power((M - t), 0.5))
d2 = d1 - sigma * WorksheetFunction.Power((M - t), 0.5)
If d1 < 0 Then
Ct = St * (1 - WorksheetFunction.NormDist(-d1, 0, 1, True) - K * Exp(-r * (M - t)) * (1 - WorksheetFunction.NormDist(-d2, 0, 1, True)))
ElseIf d1 > 0 Then
Ct = St * WorksheetFunction.NormDist(d1, 0, 1, True) - K * Exp(-r * (M - t)) * WorksheetFunction.NormDist(d2, 0, 1, True)
d12 = (WorksheetFunction.Ln(St / K2) + (r + 0.5 * WorksheetFunction.Power(sigma, 2)) * (M - t)) / (sigma * WorksheetFunction.Power((M - t), 0.5))
d22 = d12 - sigma * WorksheetFunction.Power((M - t), 0.5)
If d12 < 0 Then
Ct2 = St * (1 - WorksheetFunction.NormDist(-d12, 0, 1, True)) - K2 * Exp(-r * (M - t)) * (1 - WorksheetFunction.NormDist(-d22, 0, 1, True))
Ct2 = St * WorksheetFunction.NormDist(d12, 0, 1, True) - K2 * Exp(-r * (M - t)) * WorksheetFunction.NormDist(d22, 0, 1, True)
Worksheets("Feuil1").Cells(3, 7) = Ct
Pt = Ct - St + K * Exp(-r * (M - t))
Worksheets("Feuil1").Cells(3, 8) = Pt
Worksheets("Feuil1").Cells(3, 10) = Pt + Ct2
deltac = WorksheetFunction.NormDist(d1, 0, 1, True)
deltap = deltac - 1
Worksheets("Feuil1").Cells(9, 2) = deltac
Worksheets("Feuil1").Cells(10, 2) = deltap
Dim Nprimed1 As Double
Nprimed1 = Nprime(d1)
gammac = Nprimed1 / (St * sigma * WorksheetFunction.Power(M - t, 0.5))
gammap = gammac
Worksheets("Feuil1").Cells(9, 3) = gammac
Worksheets("Feuil1").Cells(10, 3) = gammap
vegac = sigma(M - t) * WorksheetFunction.Power(St, 2) * gammac
vegap = vegac
Worksheets("Feuil1").Cells(9, 4) = vegac
Worksheets("Feuil1").Cells(10, 4) = vegap
thetac = -(St * sigma / (2 * WorksheetFunction.Power(M - t, 0.5))) * Nprime(d1) - r * K * Exp(-r * (M - t)) * WorksheetFunction.NormDist(d2, 0, 1, True)
thetap = -(St * sigma / (2 * WorksheetFunction.Power(M - t, 0.5))) * Nprime(d1) + r * K * Exp(-r * (M - t)) * (1 - WorksheetFunction.NormDist(d2, 0, 1, True))
Worksheets("Feuil1").Cells(9, 5) = thetac
Worksheets("Feuil1").Cells(10, 5) = thetap
rhoc = (M - t) * K * Exp(-r * (M - t)) * WorksheetFunction.NormDist(d2, 0, 1, True)
rhop = (WorksheetFunction.NormDist(d2) - 1) * (M - t) * K * Exp(-r * (M - t))
Worksheets("Feuil1").Cells(9, 6) = rhoc
Worksheets("Feuil1").Cells(10, 6) = rhop
je pense t'avoir signalé hier que ton instruction
n'était pas correcte, si tu voulais définir toutes ces variables avec un type double. je t'invite à relire le message de Steelson et le mien à ce sujet.
https://forum.excel-pratique.com/viewtopic.php?f=2&t=118190
Ta variable d1 n'a pas le type correct, elle a le type variant et ta procédure attend une variable de type double.
Merci pour ton aide cela fonctionne maintenant
