VBA
J'ai fait vba : mais je pense pas que ça va pas marché car je veux que si la cellule A1393 n'est pas vide on execute la macro et sinon ne rien faire mais je n'ai pas indiqué cette cellule savez vous comment faire ?
Sub heuresréaliséessalarié3()
' heuresréaliséessalarié3 Macro
If Len(Cell.Value) > 0 Then
Range("P1325:BF1337").Select
Selection.Copy
ActiveWindow.ScrollColumn = 45
ActiveWindow.ScrollColumn = 44
ActiveWindow.ScrollColumn = 43
ActiveWindow.ScrollColumn = 42
ActiveWindow.ScrollColumn = 41
ActiveWindow.ScrollColumn = 40
ActiveWindow.ScrollColumn = 39
ActiveWindow.ScrollColumn = 37
ActiveWindow.ScrollColumn = 35
ActiveWindow.ScrollColumn = 33
ActiveWindow.ScrollColumn = 31
ActiveWindow.ScrollColumn = 29
ActiveWindow.ScrollColumn = 28
ActiveWindow.ScrollColumn = 26
ActiveWindow.ScrollColumn = 25
ActiveWindow.ScrollColumn = 24
ActiveWindow.ScrollColumn = 23
ActiveWindow.ScrollColumn = 22
ActiveWindow.ScrollColumn = 21
ActiveWindow.ScrollColumn = 20
ActiveWindow.ScrollColumn = 18
ActiveWindow.ScrollColumn = 17
ActiveWindow.ScrollColumn = 16
ActiveWindow.ScrollColumn = 15
ActiveWindow.ScrollColumn = 14
ActiveWindow.ScrollColumn = 13
ActiveWindow.ScrollColumn = 12
ActiveWindow.ScrollColumn = 11
ActiveWindow.ScrollColumn = 10
ActiveWindow.ScrollColumn = 9
ActiveWindow.ScrollColumn = 8
ActiveWindow.ScrollColumn = 7
ActiveWindow.ScrollColumn = 6
ActiveWindow.ScrollColumn = 5
Range("P1342").Select
ActiveSheet.Paste
ActiveCell.FormulaR1C1 = "Salarié 3"
Range("P1343").Select
ActiveWindow.ScrollColumn = 19
ActiveWindow.SmallScroll Down:=7
Exit Sub
Essai ceci : les scrool et beaucoup de select non essentiels
   If Len(Cells(1393, "A").Value) > 0 Then
      Range("P1325:BF1337").Copy Range("P1342")
      Range("P1342").FormulaR1C1 = "Salarié 3"
Bonsoir angel28, le forum,
je propose ce code VBA :
  If Not IsEmpty([A1393]) Then [P1342] = "Salarié 3": [P1325:BF1337].Copy [P1343]
dhany
si comme il est dit :
alors le code devrait être en "surveillance événementielle" sur Change de la feuille, non ?
@ bientôt
LouReeD
Bonsoir LouReeD, le forum,
comment ça va ? ton déménagement s'est bien passé ? j'espère que t'as pas oublié d'bien respecter toutes les traditions : soulever la jeune mariée au moment d'franchir le seuil, et pendre la crémaillère ; surtout, j'espère que t'as pas inversé, hein ? pa'c'que pendre ta femme et soulever ta crémaillère, c'est plutôt politiquement incorrect ! (même si ta crémaillère était consentante)
ton avatar actuel signifie-t-il que ton déménagement n'est pas encore terminé, et que t'es encore dans les cartons ?
si t'as eu des quintuplés, j'comprends qu'tu devais déménager dans un appart plus grand !
au cas où ça doit être une procédure événementielle, je propose ce code VBA :
  With Target
    If .CountLarge > 1 Then Exit Sub
    If .Address <> "$A$1393" Then Exit Sub
    If Not IsEmpty(.Value) Then [P1342] = "Salarié 3": [P1325:BF1337].Copy [P1343]
dhany
Rechercher des sujets similaires à "vba"
