Enregistrer chaque feuilles dans un fichier htm séparé
Voici un module ...
Function tableHTML(plage As Range) As String
tableHTML = "<head><style>table, th, td {border: 1px solid black; border-collapse:collapse;}</style></head><TABLE width=" & plage.Columns.Width & "><TR>"
With plage
    For Each colonne In plage.Columns
        tableHTML = tableHTML & "<th width=" & colonne.Width & ">" & html(.Cells(1, colonne.Column - .Column + 1)) & "</th>"
    Next colonne
    If .Rows.Count > 1 Then
        For i = 2 To .Rows.Count
            tableHTML = tableHTML & "<tr>"
            For j = 1 To .Columns.Count
                tableHTML = tableHTML & "<td bgcolor=" & DecVersHexa(.Cells(i, j).Interior.Color) & "><font color=" & DecVersHexa(.Cells(i, j).Font.Color) & ">" & html(.Cells(i, j)) & "</font></td>"
            Next j
            tableHTML = tableHTML & "</tr>"
tableHTML = tableHTML & "</table>"
End Function
Function DecVersHexa(ByVal valeur As Long) As String
    rouge = Left(Hex(Int(valeur Mod 256)) & "00", 2)
    vert = Left(Hex(Int((valeur Mod 65536) / 256)) & "00", 2)
    bleu = Left(Hex(Int(valeur / 65536)) & "00", 2)
    DecVersHexa = rouge & vert & bleu
End Function
Function html(plage As Range)
html = ""
For i = 1 To Len(plage.Value)
    deb_style = ""
    fin_style = ""
    If plage.Characters(Start:=i, Length:=1).Font.Underline <> xlUnderlineStyleNone Then
        deb_style = "<u>"
        fin_style = "</u>"
    If plage.Characters(Start:=i, Length:=1).Font.Bold Then
        deb_style = deb_style + "<b>"
        fin_style = "</b>" + fin_style
    If plage.Characters(Start:=i, Length:=1).Font.Italic Then
        deb_style = deb_style + "<i>"
        fin_style = "</i>" + fin_style
    Select Case Asc(Mid(plage.Value, i, 1))
        Case Is = 10
            html = html & "<br/>"
        Case Is > 127
            html = html & deb_style & "&#" & Asc(Mid(plage.Value, i, 1)) & ";" & fin_style
        Case Else
            html = html & deb_style & Mid(plage.Value, i, 1) & fin_style
    End Select
html = Replace(html, "</i><i>", "")
html = Replace(html, "</b><b>", "")
html = Replace(html, "</u><u>", "")
End Function
et un appel que tu peux customiser et sur lequel tu devrais pouvoir itérer avec mac (?)
Sub page()
dossier = "C:\Users\Michel\Downloads"
fichier = "test2html"
feuille = "Feuil1"
    Open dossier & "\" & fichier & ".htm" For Output As #1
        Print #1, tableHTML(Sheets(feuille).UsedRange)
    Close #1
    'ShellExecute 0, "open", dossier & "\" & fichier & ".htm", vbNullString, "C:\TEMP\", SW_SHOWNORMAL
Je ne sais pas comment te remercier, c'est tout simplement génial !
Sub page()
dossier = "/Users/Ludovic/Desktop/PLANNING/"
Dim nomfeuille As String
nomfeuille = ActiveSheet.Name
    Open dossier & nomfeuille & ".htm" For Output As #1
    Close #1
Ma petite modification pour que le nom du fichier htm corresponde automatiquement au nom de la feuille.
Petite question, peut on limiter simplement le nombre de colonne lu sur le tableur ? Si ton module le permet, autrement je supprimerais des informations que je ne souhaite pas qu'elles apparaissent sur le htm.
Merci beaucoup !
Pas de problème, la plage est ici
mais tu peux mettre ...
Sheets(feuille).range("X9").currentregion
pour les cellules contiguës à X9 par exemple
ou
selection
après avoir sélectionner une plage
ou
Sheets(feuille).range("D8:Z12")
pour la plage D8:Z12 par exemple
La plage que tu veux exporter est définie comme paramètre de la fonction tableHTML
c'est tout simplement parfait je te remercie infiniment !
Merci pour ce retour ...
Rechercher des sujets similaires à "enregistrer chaque feuilles fichier htm separe"
