OUtlook 2016 Erreur d'éxecution 9 : l'indice n'appartient pas à la selectio
Word, PowerPoint, Outlook, Access et tous les autres logiciels de la suite Office (sauf Excel)
v
vincm70
Nouveau venu
Nouveau venu
Version d'Excel : 2010
Message par vincm70 » 9 octobre 2019, 14:37
Bonjour tous le monde ,
Je suis sous outlook 2016. Et j'ai l'erreur :
Erreur d'éxecution 9 : l'indice n'appartient pas à la selection.
L'erreur est sur la ligne 10 :
Set objExcelWorksheet = objExcelWorkbook.Sheets("Feuill1")
Source du code :
https://www.datanumen.com/blogs/quickly-export-size-information-folders-pst-file-excel-file/
Dim strExcelFile As String
Dim objExcelApp As Excel.Application
Dim objExcelWorkbook As Excel.Workbook
Dim objExcelWorksheet As Excel.Worksheet
Sub ExportFodlerSizetoExcel()
    Dim objSourcePST As Outlook.Folder
    Dim objFolder As Outlook.Folder
    Set objExcelApp = CreateObject("Excel.Application")
    Set objExcelWorkbook = objExcelApp.Workbooks.Add
    objExcelWorksheet.Cells(1, 1) = "Folder"
    objExcelWorksheet.Cells(1, 2) = "Size"
    'Select a source PST file
    Set objSourcePST = Outlook.Application.Session.PickFolder
    For Each objFolder In objSourcePST.Folders
        Call ProcessFolders(objFolder)
    'Fit the columns from A to B
    objExcelWorksheet.Columns("A:B").AutoFit
    strExcelFile = "C:\Users\v.touzot\Documents\PJ\0000000000000000000000000\" & objSourcePST.Name & " Folder Size (" & Format(Now, "yyyy-mm-dd hh-mm-ss") & ").xlsx"
    objExcelWorkbook.Close True, strExcelFile
    MsgBox "Complete!", vbExclamation
Sub ProcessFolders(ByVal objCurrentFolder As Outlook.Folder)
    Dim objItem As Object
    Dim lCurrentFolderSize As Long
    Dim nNextEmptyRow As Integer
    objCurrentFolder.Items.SetColumns ("Size")
    For Each objItem In objCurrentFolder.Items
        lCurrentFolderSize = lCurrentFolderSize + objItem.Size
        'Convert byte to kilobyte
        'To convert to megabyte, use:
        'lCurrentFolderSize = (lCurrentFolderSize / 1024) / 1024
        lCurrentFolderSize = lCurrentFolderSize / 1024
    nNextEmptyRow = objExcelWorksheet.Range("A" & objExcelWorksheet.Rows.Count).End(xlUp).Row + 1
    'Add the values into the columns
    objExcelWorksheet.Range("A" & nNextEmptyRow) = objCurrentFolder.FolderPath
    objExcelWorksheet.Range("B" & nNextEmptyRow) = lCurrentFolderSize & " KB"
    If objCurrentFolder.Folders.Count > 0 Then
       For Each objSubfolder In objCurrentFolder.Folders
           Call ProcessFolders(objSubfolder)
Est ce que quelq'un peut m'apporter son aide?
Merci.
Vincent
Avatar du membre
Jean-Eric
Fanatique d'Excel
Fanatique d'Excel
Appréciations reçues : 630
Version d'Excel : 365 Personnel
Message par Jean-Eric » 30 octobre 2019, 20:34
Bonjour et bienvenue,
Et si tu essayais avec Feuil1 au lieu de Feuill1 ?
Jean-Eric
Je ne réponds pas aux M.P. non sollicités.
  • Sujets similaires
    Réponses
    Vues
    Dernier message
