Simplifier code vba Le sujet est résolu
M
MARK_TK
Membre habitué
Membre habitué
Version d'Excel : 2013
Message par MARK_TK » 25 mars 2016, 19:26
Bonsoir Je fais un code vba pour mon projet
je vois ce code peux moins simplifier et courte pour tout les autres lignes
ce code au desous est pour seulement 2 lignes, mais j'ai 13 lignes
merci d'avance
Private Sub TextBox1_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
Dim B1 As Integer
Dim C1 As Integer
If TextBox1.Value <> "" And TextBox13.Value <> "" And TextBox37.Value <> "" And TextBox121.Value <> "" And TextBox25.Value <> "" And TextBox49.Value <> "" Then
A = TextBox1.Value
B = TextBox13.Value
C = TextBox37.Value
B1 = TextBox25.Value
C1 = TextBox49.Value
D = TextBox121.Value
TextBox61.Value = (A - B) + ((0.5 * D) - C)
TextBox73.Value = (A - B1) + ((0.5 * D) - C1)
Private Sub TextBox25_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
If TextBox1.Value <> "" And TextBox25.Value <> "" And TextBox49.Value <> "" And TextBox121.Value <> "" Then
A = TextBox1.Value
Private Sub TextBox49_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
A = TextBox1.Value
Private Sub TextBox13_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
If TextBox1.Value <> "" And TextBox13.Value <> "" And TextBox37.Value <> "" And TextBox121.Value <> "" Then
A = TextBox1.Value
B = TextBox13.Value
C = TextBox37.Value
Private Sub TextBox37_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
A = TextBox1.Value
B = TextBox13.Value
C = TextBox37.Value
Private Sub TextBox2_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
If TextBox2.Value <> "" And TextBox14.Value <> "" And TextBox38.Value <> "" And TextBox121.Value <> "" And TextBox26.Value <> "" And TextBox50.Value <> "" Then
A = TextBox2.Value
B = TextBox14.Value
C = TextBox38.Value
B1 = TextBox26.Value
C1 = TextBox50.Value
TextBox62.Value = (A - B) + ((0.5 * D) - C)
TextBox74.Value = (A - B1) + ((0.5 * D) - C1)
Private Sub TextBox26_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
If TextBox2.Value <> "" And TextBox26.Value <> "" And TextBox50.Value <> "" And TextBox121.Value <> "" Then
A = TextBox2.Value
Private Sub TextBox50_Change()
Dim A As Integer
Dim B1 As Integer
Dim C1 As Integer
Dim D As Integer
A = TextBox2.Value
Private Sub TextBox14_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
If TextBox2.Value <> "" And TextBox14.Value <> "" And TextBox38.Value <> "" And TextBox121.Value <> "" Then
A = TextBox2.Value
B = TextBox14.Value
C = TextBox38.Value
Private Sub TextBox38_Change()
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Integer
A = TextBox2.Value
B = TextBox14.Value
C = TextBox38.Value
Avatar du membre
eriiic
Passionné d'Excel
Passionné d'Excel
Appréciations reçues : 255
Version d'Excel : 2010fr
Message par eriiic » 25 mars 2016, 19:41
pour simplifier moi je mettrai une listbox de 7 colonnes x 13 lignes
eric
En essayant continuellement, on finit par réussir.
Donc plus ça rate, plus on a de chances que ça marche.
(les Shadoks)
En plus du merci (si si, ça se fait !!!), penser à mettre en résolu. Merci
M
MARK_TK
Membre habitué
Membre habitué
Message par MARK_TK » 25 mars 2016, 19:59
Merci eriic mais comment ?
voila mon travail comment avec ton aider de simplifier le tableau
merci d'avance
P_B_VBA_01.xlsm
(29.12 Kio) Téléchargé 5 fois
  • Sujets similaires
    Réponses
    Vues
    Dernier message
