explication code
D
Dehbi
Membre habitué
Membre habitué
Version d'Excel : 2010
Message par Dehbi » 16 novembre 2018, 14:35
bonjour a tous
Je sollicite votre afin de m'expliquer le code suivant car il ya quelque temps un membre ma creer ce code que j'utulise et fonctionnelle
mais maintenant que je m'interesse a VBA je souhaiterai comprendre
Merci de votre comprehension
rivate Sub CommandButton21_Click()
Dim sWk As Worksheet
Set sWk = Worksheets("Extract")
    sWk.UsedRange.ClearContents
    On Error Resume Next
    iRowA = Range("A:A").Find(what:="TOTAL OVER", lookat:=xlWhole, searchdirection:=xlPrevious).Row
    iRowAA = Range("A:A").Find(what:="OVERAGE RE", lookat:=xlWhole, searchdirection:=xlPrevious).Row
    iRowD = Range("D:D").Find(what:="MPLOYEE", lookat:=xlPart, searchdirection:=xlPrevious).Row
    Do While iOK = 0
        iOK = 1
        If iRowD1 < iRowD Then
            iOK = 0
            iOK1 = 0
            iCol = iCol + 1 ' ˆ partir de la colonne A
            sCol2 = Split(Columns(iCol).Address(ColumnAbsolute:=False), ":")(1)
            iRowD1 = Range("D" & iRowD1 + 1 & ":D" & iRowD).Find(what:="MPLOYEE", lookat:=xlPart, searchdirection:=xlNext).Row + 1
            iRowA1 = Range("A" & iRowD1 & ":A" & iRowA).Find(what:="TOTAL OVER", lookat:=xlWhole, searchdirection:=xlNext).Row
            iRowAA1 = Range("A" & iRowD1 & ":A" & iRowA1).Find(what:="OVERAGE", lookat:=xlPart, searchdirection:=xlPrevious).Row
            sData = Right(Cells(iRowD1, 4), Len(Cells(iRowD1, 4)) - 2)
            sWk.Cells(2, iCol) = sData
            sWk.Cells(3, iCol) = Cells(iRowD1, 5)
            Do While iOK1 = 0
                iOK1 = 1
                If iRowAA2 < iRowAA1 Then
                    iOK1 = 0
                    iRowAA2 = Range("A" & IIf(iRowAA2 = 0, iRowD1, iRowAA2 + 1) & ":A" & iRowAA1).Find(what:="OVERAGE", lookat:=xlPart, searchdirection:=xlNext).Row
                    iRowAA3 = Range("A" & iRowAA2 + 1 & ":A" & iRowA1).Find(what:="RUN TIME", lookat:=xlPart, searchdirection:=xlNext).Row
                    iCol1 = Cells(iRowAA2 + 2, Columns.Count).End(xlToLeft).Column
                    For x = 2 To iCol1 Step 2
                        sCol1 = Split(Columns(x).Address(ColumnAbsolute:=False), ":")(1)
                        If Cells(iRowAA2 + 3, x) <> "" Then
                            For y = iRowAA3 To iRowAA2 + 3 Step -1
                                If Cells(y, x) <> "" And Len(Cells(y, x)) = 14 And IsNumeric(Left(Cells(y, x), 1)) And IsNumeric(Right(Cells(y, x), 1)) Then
                                    iRow1 = y
                                    Exit For
                            iRow2 = sWk.Range(sCol2 & Rows.Count).End(xlUp).Row + 1
                            sWk.Range(sCol2 & iRow2).Resize(iRow1 - (iRowAA2 + 2), 1).Value = Range(sCol1 & iRowAA2 + 3 & ":" & sCol1 & iRow1).Value
                iRowAA2 = iRowAA3
            Loop
            iRowAA2 = 0
    Loop
    With sWk
        For x = 1 To iCol
            sCol = Split(.Columns(x).Address(ColumnAbsolute:=False), ":")(1)
            iRow = .Range(sCol & Rows.Count).End(xlUp).Row
            For y = iRow To 4 Step -1
                If .Cells(y, x) = "" Then .Cells(y, x).Delete shift:=xlUp
            .Columns(sCol & ":" & sCol).ColumnWidth = 15
        .Activate
          ActiveWindow.Zoom = 90
          Cells.EntireColumn.AutoFit
    On Error GoTo 0
  • Sujets similaires
    Réponses
    Vues
    Dernier message
