I want to loop and extract all the rows between two different words (For Example, 56050067 and 56050068) that repeat in a column. This code get me just the first range
Thank you for intance
My table like this:
56060067(1)
A
B
C
D
F
56060068(1')
J
H
I
K
L
56043556(1'')
T
Y
J
K
N
56060067(2)
O
P
Q
W
X
56060068(2')
56043556(2'')
Code:
Sub copy()
Dim rownum As Long
Dim colnum As Long
Dim startrow As Long
Dim endrow As Long
Dim lastrow As Long
Dim s As Range
Dim e As Range
rownum = 1
colnum = 1
lastrow = Worksheets("Sheet1").Range("A65536").End(xlUp).Row
With Sheets("Sheet1") 'or this can be any other sheet where you search
Set r = .Range("B:B").Find("56050067")
If Not r Is Nothing Then
Set e = .Range("B:B").Find("56050068", r).Offset(-1)
If Not e Is Nothing Then
.Range(r, e).EntireRow.copy Sheets("Sheet2").Range("A1") 'or to whatever sheet
